Drain Water Separator - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-20-2011, 06:30 AM Thread Starter
RachHandinit's Avatar
I have an 09 f250 and the drain water separator keeps coming on. When i open the valve to drain it nothing ever comes out?????
RachHandinit is offline
post #2 of 3 Old 03-20-2011, 06:40 AM
It is possible the sensor is bad. The more likely problem is that it is clogged. I had a similar problem but did not have the light come on. There are 3 torx screws that hold the cover on. Remove the screws then take the cover off and clean it out real good. To be on the safe side I would not drive it till you cleaned it out and see if the light goes off after cleaning. Water in the engine and the hpfp is a death sentence for it. Good luck!
Ed
2009 PSD FX4 Crew Cab Bed X Liner Stock
When she's paid for mods
sportsfreaked is offline
post #3 of 3 Old 03-20-2011, 06:44 AM Thread Starter
ok thanks for the help and i know i am worried something is wrong and afraid something bad is going to happen.
