Trucks throwing codes help! - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-14-2011, 02:16 PM Thread Starter
salnazzaro's Avatar
Quoted: 25 Post(s)
Well these are the codes my trucks throwing-
U0115
U0100
U0101
P1000
Help!
2015 f350 cclb platinum...5% tint, Anzo smoked mirror lights, recon clear cabs, tgc 2.5" spacers, carli adjustable track bar, icon 5" rear blocks, Firestone riderites, B&W goosneck, line x, rancho 7000s, Fuel Mavericks wrapped in Toyo MT's, No Limit stage 2 cold air intake, 4" flo pro straight pipe, Sct w gearhead tunes, hideaway LEDs
salnazzaro is offline
post #2 of 6 Old 03-14-2011, 02:37 PM
HOUTX01X's Avatar
Quoted: 4 Post(s)
from what i have read it is common while running a sct tunner..
U0100 Lost Communication With ECM/PCM "A"
U0115 Lost Communication With ECM/PCM B
U0101 - Lost Communication with TCM
P1000 is a computer reset code which means the computer has been reset with either a programmer, unplugging the batteries, etc and it has yet to complete it's drive cycle. (from twinturbostroker)
http://powerstrokenation.com/forums/...ad.php?t=74155
'11 F250 KR
XRT Pro, H&S SX-E turbo kit, NoLimit intake/intercooler
OUO bars/blocks
-EGR,CCV,1993pf
Leveled w/ 35 atII
HOUTX01X is offline
post #3 of 6 Old 03-14-2011, 02:50 PM Thread Starter
salnazzaro's Avatar
Quoted: 25 Post(s)
Ok thanks I was worried it was transmission codes but what does lost communication mean?
post #4 of 6 Old 03-15-2011, 06:10 AM
sschefer's Avatar
If your truck is running you just need to complete a drive cycle and the codes should clear, (I think). The lost comm's (all of them) just means your battery was disconnected.
Steve Schefer
Santa Rosa, Ca
08' F350 Super Duty 4x4 OffRoad. 6.4l, Fabtech 6" lift, Procomp 20" wheels/Toyo 37's, K&N Intake. 9" total over stock lift.
sschefer is offline
post #5 of 6 Old 03-15-2011, 07:12 AM Thread Starter
salnazzaro's Avatar
Quoted: 25 Post(s)
Ok thanks for the help and info
post #6 of 6 Old 03-15-2011, 03:07 PM
bman848's Avatar
I had some of those codes a few weeks ago after my SCT install. When I changed out the DPF to the 4", I could not get one of the EGT sensors off the stock pipe. I ordered a new sensor from Ford, disconnected the battery, powered down the SCT, installed the new sensor and everything has been good since then!! No codes or anything after that.
Hope this helps!!
08 4X4 Harley Davidson Edition
4 Inch Lift
35" Hankook A/T Tires
18" A/E Chrome Wheels
Westin Polished Running Boards W/ LED
5% Tint
Bullydog Cold Air Intake
SCT Livewire Extreme, KEM Tune
4" DPF/Cat Delete
Pair of Kicker Comp. 10's behind the seat.
Soon to come:
Smoked Tail Lights
bman848 is offline
