need your opinions!!!
I called the quick lane at the ford dealership and they quoted me $250 to drop the transmission pan, change the filter and use their machine to put new transmission fluid through the whole system (about 22 quarts they said). Is it better to do that or just drop the pan, change the filter and put new transmission fluid myself?
Does the transmission pan have a reusable gasket or do i need a silicone gasket? Also does it just have a sump filter or does it also have a spin on filter for the transmission cooler like my dodge had? ![]() Thanks in advance
So you think its better to have ford do it instead of dropping the pan myself?
The best way to do it is to have it flushed with a machine that way it gets all of it out.The only difference is the fluid that is used.We do it here where I work and use BG or Mercon Sp.
well, actually any shop that has that fluid replacement pump system. I plan on dealer doing mine , Just dropping the pan you can get to the all important filter and some of the fluid, while the pump will move the old fluid out of the torque converter too.
I listen to the expert..drop the pan, change the filters and refill don't flush. Do this every 30k..per BTS.
Cary |
thanks for the advice guys!
is there something negative to the service that the dealer does? Who is the expert, Id like to read up on this?
