carquest vs OEM - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-04-2011, 06:46 AM Thread Starter
carquest vs OEM
when i changed my oil the other day, i noticed that the cap for the oil filter is a cap from carquest. i'm assuming that is not the OEM part. should i be concerned that the cap is not working as well as the filter cap that came from ford? should i replace the cap with an OEM part from the ford dealer? i watched the vid someone had posted about using cheap aftermarket filters on the 6.0s and 6.4s so i want to make sure that my filters are working properly.
wide body is offline
post #2 of 3 Old 03-04-2011, 01:03 PM
Either replace with oem or get an billet aftermarket cap. Some of the replacement caps that come with the filters are included because the cheap-o filter is a little longer or shorter than the OEM filter, and the differnt cap is needed to makeup for the difference.
Antonm is offline
post #3 of 3 Old 03-04-2011, 01:43 PM Thread Starter
billet aftermarket cap? where would i pick up something like that? are they "spec'd" the same as the OEM part?
