Can I expect 300K + miles? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-03-2011, 08:27 AM Thread Starter
Hello everyone, about 6 months ago I had a major hard on for a 6.4 and came across a Job 2 extended cab 08 with 92k. Well I put about 70-80 miles on it a day commuting to college, and now I'm up to 110xxx miles. I have a DPF delete and run a H&S XRT tuner. The truck is in the shop now for probably nothing more than a sensor (about 1 in 10 times it shifts rough on the 2-3 or 3-4 shift when its cold and it did not shift into OD the other day and I got the wrench icon, but it ran PERFECTLY fine after...) They are finding nothing wrong with it BTW (so far..) Well it cant help but make me wonder. Im only 20 years old and going to college daily and A LOT of miles are being put on the truck, Im worried my motor wont last all that long because I don't know much about the 6.4. My dad has a 7.3 and we lmpw the 6.4 is better than the 6.0 but how much better? Basically I would like be able to get at least 300K out of this truck..... If routine maintenance is done can I expect this? Thanks guys.
Parker22 is offline
post #2 of 8 Old 03-03-2011, 08:48 AM
Why is the 6.4 better than the 6.0? I love my 6.0. If you take care of the truck, it'll last. But if your runnin a high hp tune it's gonna take it's tole.
2013 Harley Davidson Street Glide, Midnight Pearl
Vance and Hines Big radius pipes
Power Commander V
Arlen Ness air cleaner
2005 F-250 SCSB Lariat FX4.
ARP Head Studs
EGR Delete
SCT X3 with IDP tunes.
Edge Insight CS w/ EGT probe
4" MBRP turbo back
Quick Tricks 58V FICM
cyclonestroker is offline
post #3 of 8 Old 03-03-2011, 08:55 AM Thread Starter
4 out of 5 people I know have had MAJOR problems with there 6.0s. Now Im not saying all are like this, and a lot of 6.4's have had many problems too. I usually run my XRT on the 80hp setting.
Parker22 is offline
post #4 of 8 Old 03-03-2011, 09:04 AM
there is a thread on here somewhere about high mileage 6.4s and there are quite a few of them running around. take a look at that thread and see what they've done to get there. from what i remember, there seemed to be a pretty even mixture of guys running "tuned" trucks and guys running stock trucks. i would suspect it will boil down to maintenance and how the truck is driven.
wide body is offline
post #5 of 8 Old 03-03-2011, 09:35 PM
michigan37's Avatar
I'm hoping for the same. I have had my truck for two years and have put almost 90k on it. I'm hoping to get well over 250k. I'm currently only running dpf delete on stock HP (trans only tune). But the way I look at it, if I can get 250k out of it and the engine takes a dump, I'm thinking I'll drop a Cummins in it. Love the truck, don't want another one.
08 F250 CC LB 4X4
Top Gun Customz Stabilizer
2.5" Newton lift w/ Bilstein 5100
Duratrac 325/60/20
20x9 Monsters
Firestone Ride Rite airbags w/ wireless control
Daily Driver
michigan37 is offline
post #6 of 8 Old 03-03-2011, 10:30 PM
with a dpf delete i think you took care of any problems with the motor wearing out faster.. thats for sure. dont see why not. im hoping for 500k plus outta my 7.3
Dietoremain is offline
post #7 of 8 Old 03-04-2011, 02:42 PM
08powerstroker64's Avatar
08powerstroker64 is offline
post #8 of 8 Old 03-04-2011, 07:18 PM
Beatngu's Avatar
The last run of the 6.0's 05.5 thru 07's had less warranty claims than the last years of the 7.3's.
If taken care of any diesel will last 300k, not including turbo's/injectors/pumps.
You'll be fine if you take care of your 6.4
2016 AG GT350
2013 Fresh150
2008 F350 Lariat Stroker
2005 F250 Lariat Stroker
2004 Mach1 6 spd Black on black
DSS 5.0L stroker
Comp cams w/ FRPP ported heads
twin Turbonetics
13psi 749 hp / 620 ft. lbs. @ 16*
E85 numbers to follow
old Kenne Belle setup at 16 psi
and so on......
600 hp / 585 ft. lbs.
Beatngu is offline
