Question..new 6.4 on the way - Ford Powerstroke Diesel Forum
Old 07-15-2007, 05:40 PM
New 6.4 should be here soon and my question is the best way to break it in? I have owned 3 Dodge Cummins and this is my first Ford Powerstroke. With the Cummins the first 1000 miles was pretty much take it easy and after that you turned it loose. Pulling loads was recommended for good piston seating and occasional red line was good. The Cummins never let me down so I hope I have the same experience with Ford. Feedback would be helpful. :
Old 07-15-2007, 06:19 PM
Read and follow the owners manual.
Also if it's an automatic I would avoid coasting and idling for at least 500 to 1000 miles. You can do this by using the tow haul. Keep the rpm's low for the first 500 miles. Don't tow anything for the first 1000 miles.
Avoid long idle periods even after breaking it in. Idling is bad for any diesel.
