Setting Autounlock
Guys I have an 08 F250. I am wondering how to set to the door locks to unlock all doors when truck is put in park.
Thanks in advanced Albert |
The following needs to be done with in 30 seconds
1. Put the key in and turn ignition to on 2. press the power door unlock control on the door panel 3 times 3. turn the ignition from on position to off then press the power door unlock control on the door panel 3 times 4.turn the ignition back to the on position 5.the horn should chirp one time This should do the trick if your truck is equipped to do this. Good luck. Ed |
It's in the owner's manual, but I believe Sportsfreaked got it right.
