6.4 coolant? - Ford Powerstroke Diesel Forum
Old 01-25-2011, 08:06 AM
6.4 coolant?
Do the 6.4's suffer from the same problems the 6.0's do with the coolant? How often do you change coolant in 6.4. And how many run coolant filters?
Old 01-25-2011, 09:53 AM
i am going to run a coolant filter and switch to cat elc. I am at about 85,000 miles right now
Old 01-25-2011, 07:21 PM
im at 38,000 and plan on doing the coolant filter as well. Just curious about the coolant itself.
Old 01-26-2011, 04:30 PM
Feedback Score: -1 reviews
Who's making the coolant filters link?
Old 01-26-2011, 05:00 PM
Here is the one I bought for my truck. http://www.dieselsite.com/index.asp?...ROD&ProdID=799
Old 01-27-2011, 07:38 AM
I just did a coolant change and installed the dieselsite filter. I just used G05 Zerex. I am only at 15,000 range. Nice Kit. Just ahve some good drill bits to drill the bottom hole for the mount in the frame. I would also snug up the hose clamps after a few heat cycles. If you are planning on installing the filter, I would drain the radiator and the block, easy to do. Then re-fill. Wont be much more in cost. Min took about 6.5 gallons. So 4 gallons of coolant and 4 gallons of distilled water. Will have some left over to throw in the bed because it will drop some after driving, the air is getting out fo the system.
Old 01-27-2011, 07:43 AM
Did you change the thermostat when you were doing all this? I will be doing this soon also.
Old 01-27-2011, 08:31 AM
I did not. If your truck has never been hot or not a lot of miles I would not.
Reason is I have got thermostats out of the box that are bad, so I usually wait to about 50,000+ for that, on all my cars.
Old 01-27-2011, 08:34 AM
mine has 85,000 miles on it.
Old 01-27-2011, 09:45 AM
I would change it. But thats me.
