'10 F350 w/6.4 or stay with '04 F350 w/6.0? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 01-13-2011, 12:12 PM Thread Starter
Quoted: 163 Post(s)
Hi everyone. I have a 2004 F350 6.0 DRW and finally got all the bugs and such out of her. No oil leaks. All is running perfect. But saw an ad for 2010 F350 with only 5k miles and wondering if upgrading to a new model is worth it.
We use the truck for hauling our 16k# 5er and usually get about 10 to 11 MPG. This 6.0 doesn't have the regen and such that the 6.4s have.
Looking for some advice....keep the 6.0 or upgrade to the 6.4. Obviously the pros are things like the changes to the interior, motor HP, etc. But what I'm really wanting to avoid is jump from the kettle into the fire so to speak especially now that my 6.0 is purring.
jd4010 is offline
post #2 of 8 Old 01-13-2011, 12:37 PM
powerstrokedub's Avatar
I love my 6.4l but if you are going to pick the 6.4 up then make sure you order a tuner and delete pipe when you get it. Your mileage towing will be much worse if you leave it stock.
Overall, if you 6.0 is running good and not giving you problems and its paid for, I would just keep it. Plus there is not diesel that sounds like a 6.0!
2010 6.4L CCLB
2007 6.7L QCSB
powerstrokedub is offline
post #3 of 8 Old 01-13-2011, 01:20 PM Thread Starter
Quoted: 163 Post(s)
Yeah...took years (literally) to get Ford to fix the rear seal oil leak but now she is fixed and with my mods (like coolant filter) and new egr and oil cooler, the truck is running perfectly. I'll be doing a few more mods like CCV, air springs and such but nothing like a tune. And yes....she is 100% paid off. So a down side is another note.
Shame that the 6.4s get worse fuel mileage. They sure are good looking trucks interior wise!
jd4010 is offline
post #4 of 8 Old 01-13-2011, 01:25 PM
I'd stick with the 6.0 that has no problems... Maybe wait until the 6.7s are a little cheaper
e99f2506sp is offline
post #5 of 8 Old 01-13-2011, 02:37 PM
jac97psd's Avatar
My 2010 when stock got an avg 16 mpg per fill up. I figure about 18 or so on the hwy. Now with the mods I got I can get anywhere from 22 mpg to 24 mpg on the hwy.
2010 F-350 CC SRW LongBed 4X4
Spartan tunes, 5 inch Flo-Pro w/ DPF Delete, AFE stage 2 CAI, Cold side piping, 4 inch down pipe, Rudy's EGR delete, Air Dog II
jac97psd is offline
post #6 of 8 Old 01-15-2011, 08:25 PM
pizza pig's Avatar
^^ i'd like to see the hand calculations...
pizza pig is offline
post #7 of 8 Old 01-16-2011, 05:57 AM
ShirtaDay.com's Avatar
Quoted: 5 Post(s)
With a "F-350 CC SRW LongBed 4X4"? Sounds like you almost always drove 55 - 65 and downhill.
'17 F-250 KR
ShirtaDay.com is offline
post #8 of 8 Old 01-16-2011, 06:09 AM
04 F350 SRW with 35's and 4.56's vs. 08 F450 with 4.88's
Stock to Stock towing - 6.4
Tow Tune to Tow Tune - 6.4
MPG stock unloaded - 6.0
MPG tuned unloaded - 6.0, mainly because of the weight and gears in the 450
MPG tuned loaded - 6.4, same reason as above, gears help plus I can only do 55 in CA.
I miss my 04, but when I latch onto the fiver, I love the 450. Overall truck I like the 6.4 so far. Keep the oil changed, coolant clean and dont beat on the truck all the time they are great. The same with the 6.0. If my 04 was a dually I would have kept it. But the pin weight was too much for the truck, the tail was wagging the dog.
Troy Simmons
08 F450 4x4
tbsimmons is offline
