tow/haul - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-11-2011, 06:24 PM Thread Starter
leftea's Avatar
tow/haul
how much do you tow or haul before you push the tow/haul button? i used it pulling a car on a heavy u-haul trailer last week, but do i need it with pulling or hauling a 250 4wheeler? it probably wouldn't hurt, just wondering at what point does it really need it. thanks
-0IIIII0-
leftea is offline
post #2 of 5 Old 01-11-2011, 07:51 PM
suban's Avatar
when its jumping between gears-keeps upshifting too soon then down shifting cause you need more power
2001 f250 extcab lariat 7.3
2003 f550 cab&chassis 6.0
2008 f350 crewcab drw 6.4
2010 f250 crewcab kr 6.4
suban is offline
post #3 of 5 Old 01-11-2011, 08:02 PM
I haul pretty decent weight(12,000) with mine and I have yet to feel I've really need it on(Havent had problems maintaining speed). The down-shifting when decelerating feels sloppy and is irritating anyways.
2008 F250, Scab 4x4, XLT, 35's
dlenkewich is offline
post #4 of 5 Old 01-12-2011, 08:10 AM
I pull a 10,000 fifth wheel and have yet to need it and this is in CO with all of our hills.
2010 F350 Dually King Ranch FX4
Edge Evolution race tuner re-programmed by PHP
S&B intake
Rudys DPF/CAT delete pipe
NRHS Sales is offline
post #5 of 5 Old 01-12-2011, 09:23 AM
golfmedik's Avatar
I usually use the tow/haul mode when towing heavier(older) cars and up. The only time I am hesitant about using it is in low traction areas and wet slippery roads. I have had the rear tires to break loose on downshift.
'01 Ex Limited 4x4 7.3L BLACK, Diablo Chipped, ProComp shocks, Rancho Stabilizer, Hellwig swaybar, V code fronts, B code rears
2013 F350 DRW CC 4x4 6.7L Lariat,TriCoat Metallic, X-Liner, B&W Turnover w/ Companion, Edge CTS, Viair 1007 Onboard Air System with Firestone Ride-Rites
2012 Sandpiper 365 SAQ weighing in at 15k.
golfmedik is offline
