New 4.56 gears installed and now traction control problems - Ford Powerstroke Diesel Forum
post #1 of 15 Old 01-05-2011, 08:51 PM Thread Starter
jmadigan's Avatar
Just had a set of 4.56 gears installed on my '08 f-350 srw and now the traction control is kicking in randomly. I'm assuming the speedo has to be recalibrated for the gears??? Just looking for some answers. thanks
PRO COMP 6" LIFT - 22" XD BADLANDS - BILSTEIN 5100'S - 6000K HID HEAD AND FOG LIGHTS - LIMO TINT - 7" IN HEADREST TV'S
jmadigan is offline
post #2 of 15 Old 01-06-2011, 03:15 AM
tricktom1's Avatar
yes on the speedo, the gear is like putting a sjort tire on it.
idk about traction control?
TEXAS MILE 261.5 MPH
tricktom1 is offline
post #3 of 15 Old 01-06-2011, 08:20 AM
Wrong. The ABS tone ring on the rear axle that the speedometer is read from is located on the carrier, so gear ratio does not affect the speedometer, only tire size does.
2012 F-150 XLT Ecoboost SuperCrew 6.5' 4x4
cartmanea is offline
post #4 of 15 Old 01-06-2011, 04:28 PM
tricktom1's Avatar
I guess i don't see the difference, if it has a lower gear the axle will spin faster at a given rpm just like if you had a short tire.
post #5 of 15 Old 01-06-2011, 05:14 PM
The speed is measure after the differential, on the carrier, not at the transmission like they used to. So, gear ratio does not affect the speedometer, but tire size does. I realize I pretty much just said the same thing, so I guess I can't pit it any simpler.
post #6 of 15 Old 01-06-2011, 05:27 PM
tricktom1's Avatar
post #7 of 15 Old 01-06-2011, 05:40 PM
Ipkyss's Avatar
it measures axle shaft/carrier speed. which does not change with gears. the transmission shifts with mph. so if nothing was re-calibrated, the truck is running more rpms then the tcm is use to, its probably shifting too late and hitting the rev limiter.
2008 F-250 6.4 Auto, CC,SB,FX4, 2" lift, 285/65/20, Spartan tuning, Elite studs, Elite egr delete/wastegate, Elite push rods, Spearco Intercooler, cold side pipe,CFM, 4"down pipe,Custom 5" DP back exhuast 543HP/1231 ft-lbs
Everything from Sean at Street diesel performance
Ipkyss is offline
post #8 of 15 Old 01-06-2011, 06:11 PM
Check for ABS codes. If the rear tone ring wasn't installed correctly or the speed sensor is dirty, it can cause false readings and mess with ABS and traction control.
post #9 of 15 Old 01-06-2011, 08:00 PM Thread Starter
jmadigan's Avatar
No ABS lights or any alkward shifting. If i leave the traction control on then sometimes it kicks on. If I just leave it off theres no problem, runs fine. I will say though these 4.56's are sweet!
jmadigan is offline
post #10 of 15 Old 01-06-2011, 08:07 PM
Ipkyss's Avatar
what size tires?
Ipkyss is offline
