Gear ratio change with 35" tires? HELP - Ford Powerstroke Diesel Forum
Old 01-03-2011, 07:04 PM
Can anyone tell me if I will need to swap out gears when I put 35s on my truck? I am guessing I will need to, in order to get stock drivability, but which gears do I need? (BTW the truck is listed in my sig and is a XLT with stock 17" wheels and tires).
Old 01-03-2011, 07:12 PM
when they come from the factory with 275/65-20's that equals 34.2''
so 35's arent much different. even if you have 3.55 gears you should be fine
Old 01-03-2011, 08:30 PM
That is true but mine came from the factory with the 17 inch wheels and the 265/70/17s so I am thinking I have 3.55 gears right......
Old 01-04-2011, 08:36 AM
What is the build date on your truck? Job 1 Around March of 07 had 3:73's.. Think they went 3:55's on Job 2 to help with gas mileage. Someone else that knows hopefully can confirm.
Old 01-04-2011, 08:49 AM
I think there is a way to find out by looking at the label in your door jam....can anyone confirm?
Old 01-04-2011, 09:24 AM
look in drivers door and read the build date then report back
Old 01-04-2011, 09:25 AM
Subscribed out of curiosity. 35's go on today, but not planning to swap gears.
Old 01-04-2011, 10:57 AM
Ok looks like the build date is 12/09. Does that mean I have 3.55s?
Old 01-04-2011, 11:05 AM
Not 100% sure but think most trucks by end of 2008 had 3:55's. Lets see what the 2009 guys have to say.
Old 01-04-2011, 11:09 AM
I run 37s with stock 3.73 gears on my cclb 7.3L with no problems.
