oil in filter housing - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-03-2011, 07:36 AM Thread Starter
new2diesel59's Avatar
Question oil in filter housing
hey guys, lookin for opinions on putting some oil in the filter housing while changing oil. makes sense to me to put some in there, what do you guys think??
2008 F250 sd ps cc sb
stock for now, in need of mpg!!
new2diesel59 is offline
post #2 of 4 Old 01-03-2011, 08:17 AM
The housing is designed to let oil drain out of it and into the oil pan when the filter lid is loosened.
To put oil in the housing with the filter installed would be alittle tough.
Really see no use in even trying, jmo.
jfinn is offline
post #3 of 4 Old 01-03-2011, 08:18 AM
dieselkane's Avatar
It will just drain back out. When you take off the cap, a drain valve is opened and the housing completely empties. So adding oil with the filter removed wouldn't really do much good.
Traded.. 03 6.0 PSD
For.. Black F250 2008 SD LARIAT 6.4 PSD 4x4, Aries Bull Bar, Westin chrome running bars, Dura Liner, B&W Gooseneck hitch, Recon smoked taillights, Icon 4.5" lift, 35" Toyo M/T, etc... Running Spartan Tunes
AFE PG 7, Flo Pro 4" DP Back, thanks to Cobb's Diesel. It has been great so far.
Originally Posted by azkcr View Post
So all that work and you're keeping the trash can of doom on the exhaust?
dieselkane is offline
post #4 of 4 Old 01-03-2011, 09:19 AM Thread Starter
enough said, should have been common sense i guess, thx
