Cab lights going out - Ford Powerstroke Diesel Forum
Old 12-18-2010, 05:13 PM
Am i the only person who is having problems with cab lights burning out? I think in going on my 3rd bulb. They cant have many hours on them with only 25000mi.
I'm going to get some led lights. Anybody have any suggestions?
Old 12-18-2010, 05:20 PM
Cool Mmmhmm...
I have just over 50,000 and I've replaced 4 of the 5 already... you're not alone!
Old 12-18-2010, 07:18 PM
It is just frustrating changing one at a time. Thats why i want to do the leds. I think I will get the recon bulbs.
Old 12-20-2010, 04:14 PM
Cool $$$
$9.95 each for the Recon LED Bulbs... is that right?
Old 02-17-2011, 09:59 AM
having same problem with my super duty. Could it be an electrical power surge type issue?
Old 02-17-2011, 11:41 AM
I've had to replace every single one of mine a few times, and I also have two out right now.
Old 02-17-2011, 11:45 AM
Jimd1050- you are correct the replacement bulbs are at 9.95.
Is that for a set or a single bulb? I have never replaced them myself but how hard is it to do?
Old 02-18-2011, 06:53 AM
08powerstroker64 very easy, on the outside of the lens aft end is a screw, just take the screw out lift the cover off and the bulb is exposed, change out the light, when you go to put the lens cover on make sure the gasket is lined up with both lens and base of lens cover or it may leak. No more then 10 minutes max. $9.95 is for EACH bulb!
Old 02-18-2011, 07:08 AM
The Recon sets have a good warranty too
Old 02-18-2011, 07:53 AM
sweet thanks
