Upgrade from 7.3 to 6.4???? - Ford Powerstroke Diesel Forum
Old 06-28-2007, 02:36 PM
How do these new trucks compare to the old 7.3? I was debating on trading to a new 6.4 or even the 6.7. The old 7.3 has been very good to me and it only has 60,000 miles on her. How does the 6.4 pull compared to the 7.3? I pull a 25ft flatbed with a tractor. About 9000Lbs total. The 7.3 handles it ok I would say. The auto in these trucks just does'nt cut it for me.
Old 06-28-2007, 02:51 PM
im fat and ugly
oh man if you only have 60,000 miles on yur 7.3 KEEP IT you can do some mods to it and have it pullin awesome
Old 06-28-2007, 03:11 PM
Send a message via AIM to jngreen
yep yep, I agree. Put a new, built, slushbox in it and add some serious mods and you will still come out ahead....
Old 06-28-2007, 03:16 PM
Sound like I'd be crazy to part ways with the 7.3 , Its only an F-250 SWB 4x4. I was going to get the F-350. Maybe I'll hold on to it a while. Seems like there worth more money (7.3) as the days go by.
Old 06-28-2007, 03:18 PM
im fat and ugly
yeah man that 7.3 with that low of miles is "priceless" keep that baby
Old 06-28-2007, 03:20 PM
Thats Mr. Oil Leak.....
Holy cow 60K on the clock. Keep it atleast another year!
Old 06-28-2007, 03:45 PM
Nothing is priceless. Everthing I have is for sell for the right price. Even the Ole Lady.... Yea its got low miles. It just seems you can get top $$$$ if you get fid of them before it shows 100,000. I can make $$$ on this rig. But, I'll probally roll it another yr or so before going back to a 1 ton.
If you choose to upgrade to a 6.4, at least wait till the second year comes out.
F250's are the same as F350's, btw....
The question that seems to keep coming up week after week is
" What is the difference between a F250 and a F350"
Here it is:
There are 3 differences between the SRW 250/350...
1) F-250 vs F-350 badges
2) 2" rear spacer block in 250 vs 4" in the 350
3) *most important* GVWR for F350 SRW is 9900 in most states and the F250 8800 in most states.
From 99 to mid 2001 the srw trucks came with a Dana 50, Ford started using the Dana 60's on all F250/350's from mid 01 to present ,the front axle is identical on both trucks, including springs.
Springs in the Source Book are EXACTLY the same:
Front Leaf 250/350
3600lb 1.12"(thickness) 55.63"(length) 3.00"(width) 350(deflection)
4000lb 1.18"(thickness) 55.63"(length) 3.00"(width) 370(deflection)
4400lb 1.18"(thickness) 55.63"(length) 3.00"(width) 390(deflection)
4800lb 1.18"(thickness) 55.63"(length) 3.00"(width) 410(deflection)
5200lb 1.18"(thickness) 55.63"(length) 3.00"(width) 430(deflection)
6000lb 1.25"(thickness) 55.63"(length) 3.00"(width) 470(deflection)
Rear Leaf 250/350
6830lb 6(leaves) 3.86(thickness @ pad) 58.1"(lenght) 3.00"(width) 320/670/1209(deflection lbs/sq") 3603(rating@pad lbs/spring)
Rear leaf DRW
8250lb 6(leaves) 3.95(thickness @ pad) 58.1"(lenght) 3.00"(width) 350/730/1270(deflection lbs/sq") 4187(rating@pad lbs/spring)
__________________
The One who Doesn't Play Well WIth Others
directly from Super Duty And Heavy Duty: ______SUPER DUTY Tech Folder_____ - Ford Truck Enthusiasts Forums
Old 06-28-2007, 03:48 PM
I'd be getting another Dulley. So add the extra $$$ for the tires.
Old 06-28-2007, 03:49 PM
Or you can throw a set of Firestone Air bags on the rear of your truck for 250 bucks and be able to haul more weight than a 350.
