6.4L Oil Change - Ford Powerstroke Diesel Forum
post #1 of 40 Old 11-23-2010, 09:19 AM Thread Starter
j21black's Avatar
Quoted: 15 Post(s)
6.4L Oil Change
I am getting ready to change the oil on my 6.4L myself for the first time hopefully this evening. Dealer performed the first 2 changes.
I remember reading in a thread several weeks ago to break the filter seal with the drain plug removed as the filter hold a quart or so of oil.
I tried searching for the thread but nothing came up. Anything else in particular I should do? Do in need to place oil on the seals silimliar to a spin on filter or not? I have already purchased a motorcraft filter, the copper washer, and the oil. Also have a 30m lift I will be using. Anything else I should be on the lookout for?
j21black is offline
post #2 of 40 Old 11-23-2010, 09:24 AM
tjbrowder's Avatar
Sounds like you have it covered.
I change my filter before draining the pan....as you note, let's the oil drain out of the filter housing first. Do put some oil on the new O ring on the oil filter cap.
2011 F450 CC/LB 4X4
2010 F250 CC/SB FX4 *SOLD*
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website (Powerstroke.org or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my truck, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
tjbrowder is offline
post #3 of 40 Old 11-23-2010, 09:44 AM
mjc
Is it a 30mm or 36mm socket? I'm thinking 36.
2008 6.4L 4X4 CrewCab
mjc is offline
post #4 of 40 Old 11-23-2010, 10:05 AM
tjbrowder's Avatar
it is a 36
2011 F450 CC/LB 4X4
post #5 of 40 Old 11-23-2010, 11:50 AM
Make sure your drain pan is big enough It sucks using one that gets brim full.
Here's what I do:
1. loosen oil filter
2. remove drain plug
3. change filter, lube new o-ring, reinstall until cap bottoms out (going by the torque spec can sometimes leave the cap loose due to o-ring resistance)
4. reinstall drain plug, torque to spec (I tend to over-tighten and strip things)
5. add 14 quarts of oil, run a few minutes, check level, usually all mine needs
2012 F-150 XLT Ecoboost SuperCrew 6.5' 4x4
cartmanea is offline
post #6 of 40 Old 11-23-2010, 03:33 PM
04hdfatboy's Avatar
Quoted: 4 Post(s)
so does the oil filter screw on like other vehicles? Also if your facing the truck there are 2 canisters. Is the oil filter the canister on the left or right?
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #7 of 40 Old 11-23-2010, 04:30 PM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
Feedback Score: 4 reviews
on the right towards the rear. the canister filter clips into the cap then screws back down onto the housing
the other one is the secondary fuel filter housing
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #8 of 40 Old 11-23-2010, 05:07 PM
oil filter is on the passengers side.
08 F250 white/tan King Ranch
SOLD
Spartan Tuned, Powerstroker67 5" delete pipe, 5" Magnaflow exhaust with muffler
2011 F150 FX4
fordguy1715 is offline
post #9 of 40 Old 11-23-2010, 07:27 PM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
yeah sorry i meant left
-Matt
2015 F-250 XLT 6.7L
post #10 of 40 Old 11-23-2010, 07:31 PM
jac97psd's Avatar
Here's what I do:
14 quarts? It says it holds 15.
2010 F-350 CC SRW LongBed 4X4
Spartan tunes, 5 inch Flo-Pro w/ DPF Delete, AFE stage 2 CAI, Cold side piping, 4 inch down pipe, Rudy's EGR delete, Air Dog II
jac97psd is offline
