Turbo Peak PSI? - Ford Powerstroke Diesel Forum
Old 09-15-2010, 04:33 PM
Turbo Peak PSI?
What is the turbo supposed to spool to? Mine never seems to get past 30k. I swore when I test drove one of them, it hit 40k. Did I just see something wrong? Or is mine not spooling up as high as it should?
Old 09-16-2010, 06:12 AM
When mine was stock, I would see about 37 psi max. Now I see about 45psi.
Old 09-16-2010, 07:47 AM
Based on you saying it got 37, i called the dealer and said I was concerned I was only hitting what appears to be 29. Never crosses 30 for sure. The service guy said 32 psi was stock max. Can anyone else confirm or deny?
Old 09-16-2010, 07:59 AM
My truck is a manual so I don't know if that makes any difference or not.
Old 09-16-2010, 08:18 AM
Dont Mess With Texas!
im seeing around 32-36 bone stock automatic truck, idk if elevation and weather has anything to do with it but i live at 15ft. above sea level and hotter than all get out with about 110% humidity
Old 09-16-2010, 08:20 AM
scuffs *****
Send a message via AIM to Tyler
How do you get 110% humidity?
Old 09-16-2010, 08:22 AM
come down to south texas and you will see you even during the day it feels like you are walking through a wicked dense fog outside when its 110 heat index it is so friggin hot!!!
Old 09-16-2010, 08:30 AM
<<< 6.4 Powersmoke
I easily see 40 PSI or more out of mine.
Old 09-16-2010, 08:32 AM
I have been to south tx many times and I think he is under estimating the humidity at 110%!!!
Old 09-16-2010, 08:42 AM
no joke! at midnight the other night, it was 90 degrees and 95% humidity. and then the following four weeks were all over 103.
and stock, my truck would hit around 34-37psi. now i see somewhere around 50.
