F$@&%ing Ford - Ford Powerstroke Diesel Forum
Old 09-10-2010, 10:53 AM
F$@&%ing Ford
working on removing the doc/dpf pipe off and where downpipe's flange meets doc, it turns out someone welded those those bolts up. I managed to cut one of them off, now need to run to homedepot to get some more metal blades.
AM I the only one with bad luck, or has anyone's flange was welded as well?
Old 09-10-2010, 11:09 AM
The nuts are welded on. The bolt needs an extension and a swivel toreach them from the front.
Old 09-10-2010, 12:11 PM
I hope you're kidding...
Old 09-10-2010, 12:12 PM
Me too......
Old 09-10-2010, 12:29 PM
So much for being able to put it back to stock.
Old 09-10-2010, 12:43 PM
Back to stock can be done, I have done it there is no permanent damage.
Old 09-10-2010, 01:01 PM
Yes, but that is an obvious tell tell sign that you have taken it off.
Old 09-10-2010, 02:48 PM
No it is not. the nut stays in place. the bolt just threads out. Why would you need to cut the bolt off?
Old 09-10-2010, 04:51 PM
I was kidding guys. LOL I was taking a beer break and wanted to cause some drama. Everything is on, just installed the 250 tune and now im epoxying the dpf back pressure sensor. Broke it right where the rubber hose meets the sensor. if it doesnt work too well, I'll just order one online as it is 130 from a stealership.
PS: Those downpipe flange bolts were a pain in the a$$ to get out, especially the top one.
Cranked the truck up after the tune was installed and you can right there tell a difference in sound. much more meaner sounding!!
Old 09-10-2010, 04:59 PM
You will never want to go back to stock now. You will wait as long as you can if you have to take it back to the dealership for any work. I am jonesing to tune my 2010. Just want to get a few more miles on her and my free oil change.
