what is better the 6.0 or 6.4 - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By mike 6.0
post #1 of 10 Old 08-23-2010, 04:57 PM Thread Starter
I have an 05 6.0 f350 havent had much of any problems and my trucks at 150,000 mile i was thinking of getting a new truck what does anyone think of the 6.4? is it any better than the 6.0? i heard it was close to the same motor with minor differances? whats ur imput?
thanks matt
thats how I roll
suzuki250 is offline
post #2 of 10 Old 08-23-2010, 05:15 PM
C-STROKER's Avatar
i dont know if it is any better they both have there minor problems.
i do know that the 6.4 get terblle gas millage right out of the gate.
but they are night and day difference as for motors. the only thing they have in common is that the both have eight cylinders and are made by international. the 6.0 is a huei injection like the 7.3 the 6.4 is a common rail injection like the fummins, it also is a twin turbo.
96 f250 4x4
ZF5
4.10s
6637 intake
fpr shim
ccv mod
need a paint job mod
C-STROKER is offline
post #3 of 10 Old 08-23-2010, 06:12 PM
jac97psd's Avatar
6.4 makes tons of power with very few mods where the 6.0's take alot more mods to make the same power.
2010 F-350 CC SRW LongBed 4X4
Spartan tunes, 5 inch Flo-Pro w/ DPF Delete, AFE stage 2 CAI, Cold side piping, 4 inch down pipe, Rudy's EGR delete, Air Dog II
jac97psd is offline
post #4 of 10 Old 08-23-2010, 08:08 PM
08spartan250's Avatar
6.4 is better hands down. the gas mileage isnt great stock, but a few mods and that will be fixed.
-Mike
2005 F-250 Lariat
Originally Posted by azkcr View Post
And you didn't know Cummins can manage 127mpg??? They also deliver babies, go to Mars, and cure AIDS. DUH
08spartan250 is offline
post #5 of 10 Old 08-24-2010, 07:29 AM
white07's Avatar
Why does everyone say that? my 6.4 got over 17 mpg on the 200mi trip home from the dealer
Hands down, the 6.4 is better...or I should say I like the 6.4 better, a lot better
2001 Estate Green Metallic Limited Excursion w/ 7.3L and 2012 White Platinum Metallic Tri-Coat King Ranch F250 w/ 6.7L
white07 is offline
post #6 of 10 Old 08-24-2010, 02:24 PM
C-STROKER's Avatar
that great that your truck is getting 17mpg. is that hand calculated or by you truck cpu. cause my boss and cousins truck get like 12-13 mpg from the factory
96 f250 4x4
ZF5
4.10s
6637 intake
fpr shim
ccv mod
post #7 of 10 Old 08-24-2010, 02:54 PM
jac97psd's Avatar
For some reason the 2010 trucks are getting great mpg. I don't know cause they are so new or ford did something to it different then others but when my truck was stock I was avg about 16.5 per fill up and that was hand calculated. But I do about 90% hwy driving. I got my truck in June and I already have 11k miles on the truck.
jac97psd is offline
post #8 of 10 Old 08-24-2010, 04:01 PM
There are pros and cons to both engines.
We all know what the 6.0 weaknesses are. Once those are taken care of, it can be a great engine. It's also easier to work on than the 6.4.
The 6.4 is also a great engine but the emissions equipment is the only negative. Tuned, it can produce huge amounts of power that is unmatched. It's much harder to work on it though because it's so cramped inside the engine compartment.
I would go with the 6.4 because of the refined body that wraps around it. The 08 - 10 truck bodies is much better IMO. But remember for major engine work the body has to come off.
Front Runner is offline
post #9 of 10 Old 08-25-2010, 07:38 AM
My '08 F-350 is as big as it gets, dually, 4x4, long bed, crew cab, 4.10 LS, automatic, gooseneck hitch -- probably 9500 pounds rolling with my family and vacation gear. And I get 17-18 MPG on 100% highway hand calculated trips if I can keep my foot off the accelerator and keep speeds under 65 MPH. Putting around town, it's closer to 12-13 MPG hand-calculated.
1) Don't trust the in-dash MPG measurement. It clearly lies. When it says 15 MPG average for a mixed city-highway tank, my calculator and a consistent fill level shows me 13.
2) Keep speed under 65-67 MPH if you can. These trucks have a huge frontal area, and wind resistance becomes a major obstacle as speed increases. A truck that gets 18 MPG on the open highway at 60 MPH probably gets 13 MPG at 75 MPH. Keep an eye on the turbo boost -- I try to keep my boost under 7 PSI on the highway if I'm trying to stretch the miles on a tank between stops.
Greg
hammong is offline
post #10 of 10 Old 08-25-2010, 07:45 AM
mike 6.0's Avatar
spend the fuel money have fun don;t clog up the freeway like the prius checking his mileage at 55 in a 65.
andyroof likes this.
mike 6.0 is offline
The Following User Says Thank You to mike 6.0 For This Useful Post:
andyroof (04-03-2017)
