what size tire on stock 2008 20"? - Ford Powerstroke Diesel Forum
Old 08-17-2010, 09:34 AM
hey guys,
I've tried looking around the forum for the answer... seen a couple responses. Just wanted to make sure before I purchased the tires.
Question is, on my 2008 F350 w/ stock 20" rims will 305 12.5 20s fit?
I will being buying the icon 2.5 leveling kit also.
Thanks for your replies!'
JBB
Old 08-17-2010, 05:45 PM
Warheads on Foreheads
well 305 12.5 20 isn't a tire size. 305 and 12.5 are both the width of a tire. but with a leveling kit guys run a 35X12.5X20 tire with no problem, hell some even run a 37X12.5X20.
Old 08-17-2010, 06:06 PM
I run 12.50x35x18 with out lift. had lift but took it off .all kinds of room.
Glad you knew what I meant... Was comparing the 305 and 12.5 before wrote the email...
Anyways, thanks for reply... Buddies that own offroad shop are now trying talk me into icon 4" and new wheels (at cost... But still some $$)
any suggestions on wheels? What would look good on long bed, black f350 4x4 with topgun bumper (similar ranchhand)?
Old 08-17-2010, 07:02 PM
Icon 4.5" lift. 22" rims. 37" M/Ts. I think it would look good. Could even go with a 6" lift.
Old 08-18-2010, 01:44 AM
if you want a good look take a look. this is 6" LIFT in the front and 4" lift in the rear with 37's and 20" wheels. if your looking for a nice black wheel that no one has, take a look ate ION
by the way, YES you can "fit" 37's with the 2.5 lift, but its tight and i would go with 35's if you go that way.
i used to work for the LES SHWAUB team that did my whole set up, and they, like many that do the work are quick to give you a general answer like to do the 4" icon lift, but if you read around this forum and ask the guys they will tell you the newer fords are a bit different than other trucks. *i know because i they helped me*
-Jackson
what size tire on stock 2008 20"?-40979_1447296716905_1667804343_1038851_1300809_n.jpg   what size tire on stock 2008 20"?-33512_1447296956911_1667804343_1038853_180457_n.jpg
Old 08-18-2010, 04:56 AM
leveling kit with rear blocks and 35s
Nitto 35x12.50/20 on factory 20s. 2" Leveling kit w/rear blocks
Old 08-18-2010, 07:05 AM
I just ordered 295/65/20 for my stock 20" rims, and I will be running 100% stock Fx4 F-250 suspension. Should fit like a glove!
Old 08-18-2010, 07:36 AM
-Jackson
Jackson,
Thats a sick lookin truck! Damn, I'll have to save up to do that setup... proly stick to my original plan at the moment and do 2.5" icon with 35s on stock.
I'll check out ION thanks for the input. How much the 6" lift run you?
Old 08-18-2010, 07:26 PM
Originally Posted by JBB66 View Post
Jackson,
thanks man, trust me i did some saving too!
as for your QUESTION.... i cant help you with the price.... not sure what it would be cause i got a big discount on it. i used to work for LES SHWAUB TIRE before the military (current job) so the gen manager hooks me up. i will tell you that i payed $4,500 for the mess~!
