"Low Power" Spartan Tunes - Ford Powerstroke Diesel Forum
Old 08-16-2010, 05:29 AM
I've read a lot about the 210, 250 and 310 tunes on the Spartan but I am not necissarily looking for those crazy numbers. Has anyone used the "lower" HP tunes such as the 40, 75 or 120 off-road tunes? What kind of fuel mileage gains can I expect running one of these vs the high performance tunes? Is anyone running these?
Old 08-16-2010, 08:00 PM
Warheads on Foreheads
pretty much everyone says if you want higher MPG and run high HP tunes
Old 08-20-2010, 11:19 AM
IMHO, the best result of the Spartan will probably be less fuel in the oil. I'm not looking for extreme power, either. It pulls very well, in stock configuration, with my 14,800 lb fiver behind it.
Old 08-20-2010, 11:21 AM
Everyone I have talked too, including Spartan directly, said to run the 275 tune for the best MPG increase.
Old 08-20-2010, 08:34 PM
Spartan has nothing to do with less fuel in the oil other than the fact Spartan permits optional removal of the DPF, and therefore no DPF regeneration cycles.
Old 08-20-2010, 09:35 PM
I see that you understand my point.
