NO COMPASS OR OUTSIDE TEMP DISPLAY on my truck any way to add - Ford Powerstroke Diesel Forum
Old 08-15-2010, 07:43 AM
sorry if i reposting this cant find original not sure if i finalized last post, anyway is there any way to add it?
didnt realize how much i used it in other truck till i bought this one with out it
Old 08-15-2010, 08:35 AM
I bought one from ebay for a chevy or it might have been universal. It fits right on the window mount and there is minor wiring involved. Now i have outside temp and compass in the rear view mirror. Works great
Old 08-15-2010, 12:47 PM
do u know company u bought it from
Old 08-15-2010, 02:07 PM
Warheads on Foreheads
try this.
http://motors.shop.ebay.com/i.html?_...506.m270.l1313
It is a Gentex mirror from D-N-D Enterprises. Good Luck
Old 08-15-2010, 03:11 PM
Gentex auto dimming mirror w/ compass and temp
Old 08-16-2010, 06:37 AM
What options do you have on your truck? The message center should have the compass display on it and as far as outside temp, if you have the climate control system, you will have a button in the middle labeled EXT which is for external temperature. If you don't have that button, then you will have to change out the mirror or something to get the temperature like mentioned above.
Old 08-18-2010, 07:19 AM
I have been looking into this as well - is their an additional sensor or something needed for the mirror to read the outside air temp? Or is this pretty much a plug and play setup?
Old 08-18-2010, 09:48 AM
You'll need to install the temp sensor and run the wire for temp and power.
I installed mine in about an hour, start to finish. I had bought it off ebay with the full length of wire. Many of them on ebay come with a sensor with a little stub of wire and then the mirror with the stub of wire. You have to supply the wire and splice it all together.
Old 08-19-2010, 11:38 AM
thanks guys,
chongo let me know what one u go with
Old 08-19-2010, 12:58 PM
Originally Posted by highroller355 View Post
thanks guys,
Ill be going with a gentex but not right now there is other stuff I have to do to the truck first.
