What size is the pitman arm NUT ????????????????? - Ford Powerstroke Diesel Forum
Old 08-06-2010, 08:24 AM
Send a message via AIM to cj performance
Need to know what size that big nut is on the pitman arm. its come loose cause i just used a small pipe wrench to tighten it. need socket to impact it on
ONLY FOR 2008 as older trucks i looked and its way smaller..
Old 08-07-2010, 10:43 AM
ok well its 1 13/16 if anyone ever needs to know
Old 11-02-2010, 05:59 PM
Thank you thank you. I needed to make sure i had the right size socket to take the nut off. Now I just have to make sure I have the right puller at the shop.
Old 11-02-2010, 09:32 PM
My 05 is the same size.
Old 11-02-2010, 10:04 PM
KING of BLING!
Should be the same for 05-up trucks but I'm not 100% on that. Cj are you taking your lift off??
