Any 450 owners with DPF delete and tuned? - Ford Powerstroke Diesel Forum
Old 07-20-2010, 11:47 AM
I'm looking to see what kind of fuel mileage you are getting with the DPF delete and some kind of tune. What kind of weight are you pulling also and the type(stop and go, hills, etc..) of trip?
Thanks
Old 07-20-2010, 12:04 PM
I do not have the DPF delete or tune.... YET but i can tell you what i get stock... I average between 11.5 and 12 at 65-75mph
Old 07-20-2010, 12:59 PM
I have a four wheel drive 450 with the 4.30 gears. Running the Spartan 210 heavy tow tune all the time and I just averaged 18.7 according to the computer on a 200 mile trip to the coast. I know its not very accurate but stock it would have been around 13 or 14.
When I tow my trailer I can get about 10 on the computer if I keep the speeds down. That's normally on slightly curvy highways without alot of stop and go. Trailer is about 18k or 19k depending on what I have in it. I have also been tuned for about 13,000 miles. Pulls like a different truck then stock, I wouldn't tow without the tune now.
Old 07-20-2010, 01:15 PM
I would see almost a double in fuel-mileage if I deleted and tuned, nice. I'm trying to see if getting double the fuel mileage is better for the environment vs. Clean air from the DPF.
Thanks for the input!
Old 07-20-2010, 02:08 PM
I highly doubt you get double. Don't trust anything the lie-o-meter says. You need to check the mileage, don't trust the read out on the dash - I hear it gets way off when tuned. My F250 stock is 1-2 MPG off either direction then the read out.
Old 07-20-2010, 07:56 PM
Anyone running 4.88's? I'm getting 10mpg stock at the moment.. spartan's in the mail!
Old 07-21-2010, 09:09 PM
Send a message via AIM to foursixtysix
I have the 4.88 gears, use the spartan 250 daily. I don't haul a load stock my truck was steady at 9.2 last I calculated on a mostly highway trip was 13.5. For sure would not expect to double your mpg. When I hand calculated my lieometer was saying an even 17
Old 07-22-2010, 05:48 AM
Let's hope for at least 15. Otherwise I'm parking this truck and running my 7.3 that gets 18 mph everywhere
Old 07-22-2010, 03:58 PM
I have an 08 f-450 with 4.30 gears tuned by Spartan with cat and dpf delete. I get 10mpg (hand calcul) pulling 20 to 21k on flat ground with the 210 tow performance tune. Empty I have seen 17 with the 250 tune. With this setup and the 60 gallon fuel tank, I can drive all day and not stop for fuel. Get it, you will not regret it!
Old 07-22-2010, 05:15 PM
I also am seeing 15-17 empty on the 250 tune. And for sure, go ahead and do the nasty, you will not turn back...lol
