Fuel Tank Water Drain - Ford Powerstroke Diesel Forum
Old 07-16-2010, 05:20 PM
Went to drain my again tonight, and it just dripped out, no constant flow like it normally does. Probably a drip every 5 seconds.
Good news, no water, but curious if I need to have the unit replaced. Not sure if this is normal or not, but when I pushed the lever over, the entire pipe rotated with the lever.
Probably should have titled it Fuel System as opposed to Fuel Tank, but I can not figure out how to edit the subject line.
Old 07-16-2010, 07:25 PM
How much fuel was in your tank?
Old 07-16-2010, 07:45 PM
3/4 of a tank
Old 07-17-2010, 02:11 PM
bump - anyone?
Old 07-17-2010, 04:07 PM
sometimes mine gets clogged with road grime, took it to the dealer once and they shot air in it with a compressor on low PSI, opened it right up. I have to do that every now and again to get it flowing again.
