Oil on top of turbos? - Ford Powerstroke Diesel Forum
Old 07-05-2010, 08:11 AM
Just wondering if anyone else has seen this? Truck is running great just wanna make sure this isn't a big deal before I install my new downpipe and exhaust this weekend.
Old 07-05-2010, 09:07 AM
That looks more like something got spilled on the turbos. The oil lines are not leaking. Try cleaning it off and see if it comes back.
Old 07-05-2010, 09:15 AM
yea thats an odd area. Did you recently have your oil changed? I agree with greasltn, clean it off and see if it returns
Old 07-05-2010, 09:56 AM
the first time i noticed it was right after an oil change but i don't remember it being that much. just got done cleaning most of it off and i kind of looks like it is coming from the small bolts on top the one on the drivers side had stuff running down the back side as well.
Old 07-05-2010, 11:18 AM
that bolts only purpose is to hold the heat shield on. Im sure the oil just seeped under it when the shield got hot.
Old 07-06-2010, 08:12 AM
I checked the bolts and they weren't very tight so I went ahead and tightened them a little. I'm assuming that since no one's told me to go to the dealer or to a mechanic that it's probably nothing serious????
Old 07-06-2010, 08:22 AM
If you clean the oil off and it comes back, the only thing I can think of would be cracked turbo housings and bad bearing seals in the turbos. I also think if this were the case, you would notice a running issue. So long story short, you shouldn't have anything to worry about.
