what gears do i have
i have a 2008 ford f350 dually and i get around 10-11 miles to the gallon. a friend asked me what is the gear ratio that i have and i couldnt tell him. how can i go about finding out what gears i have, is there a specific letter/number in the V.I.N. and if you have any suggestions on better fuel economy
Is there a tag on the differentials that say? Being that it's a dually, it may have 4.10s.
not near my truck now id have to check
any suggestions on fuel economy
you need to check the axle code on the door sticker then look it up
thaks alot. one quic question though, should i call the dealer with the axle code or is there some where on the internet i could research this axle code
Just did a search for "Ford Axle Codes" and a bunch of hits came back so you should be able to find something out there.
What RPM do you run at 70, if you run in the 1700's your a 3:55, if you run in the 1800's you 3:73, if your around 2000 + your a 4:10. Im not sure if they had 3:55 for 2008, so its either a 3:73 or 4:10
My 08 had 3:73 and ran in the 1800's My 10' has 3:55 and runs in the 1700's |
i run around 2000rpm at 70mph so according to this i have 4:10 which would explain my poor gas milage. anybody out there in the same boat. yall have been very helpful so far. i pull a fith wheel camper on ocasions and when i hook up to that thing u looking at aroun 8 mile to the gallon. i know a tuner would help but whats cheeper, new gears or a tuner
A numerically low gear ratio can be just as bad as one that is too high. |
