Ag Diesel in the 6.4 ?? - Ford Powerstroke Diesel Forum
Old 06-19-2010, 01:31 PM
Has anyone out there tried running farm diesel in their 6.4? If so did it change the performance. The sulfur is higher so I was concerned it may not run well in it.
Old 06-19-2010, 01:33 PM
Feedback Score: 7 reviews
Send a message via AIM to dereku
It should clog the DPF I believe. Delete the DPF and straight pipe it then I see no reason why you couldnt run it.
Old 06-19-2010, 01:46 PM
Deleting the DPF....., will that give me better fuel economy?
Old 06-19-2010, 03:01 PM
I remember reading somewhere that a few people were running red diesel in their trucks. From what i remember, it ran exactly the same. Im fairly certain that there is NO performance difference between off road diesel and diesel you get from the pump. The only difference is the tax and red dye. If you get caught running the red diesel, its a hefty fine.
Deleting the dpf will require a tuner. If you just take the dpf off without a tuner, the truck will go into permanent regeneration
But to answer your question, yes deleting the DPF will give you better mileage, however you run the risk of voiding your warranty
Old 06-19-2010, 05:08 PM
Were they running red diesel without deleting the DPF?
Old 06-19-2010, 05:31 PM
Red diesel is the same. It's ulsd with red dye in it. ULSD is all that is made anymore...
Old 06-19-2010, 06:10 PM
Do you know of anyone running it in there 6.4?
Old 06-19-2010, 06:13 PM
no, ulsd is all most stations have, theres plenty of places that have lsd and farm diesel
Old 06-19-2010, 06:20 PM
Are there any Ford techs on here that could answer the question? I would sure hate to mess up my truck and or void the warranty.
Old 06-19-2010, 06:36 PM
Oh you will for sure void your warranty if a drop of red diesel gets in your truck, anything fuel related that goes wrong they will look in tank and see its dyed red and void your warranty, you will have to remove the dpf to run it anyway but deleting the dpf will void your warranty if you take it in without the dpf on. Its a slippery slope.
