Serpentine Belt, How hard to change? - Page 3 - Ford Powerstroke Diesel Forum
post #21 of 34 Old 06-28-2010, 08:44 PM Thread Starter
a truck
Matt P's Avatar
Originally Posted by jberzerker View Post
im taking my truck into the dealer tomorrow to get the tensioner checked out and the belts too, its been squeeling like mad lately and driving me crazy. So hopefully the tensioner is covered under warranty. I'm also braving taking it in without the DPF so we'll see how that ends up.
If it was me Id put that DPF back on to play it safe, I always but that and the stock intake on if its going to the dealer, unless the dealer is cool with it
03 king ranch w/ a cummins
Matt P is offline
post #22 of 34 Old 06-28-2010, 08:53 PM
jberzerker's Avatar
Well I talked to one of the mechanics and he said they are good with working on modified trucks, so we'll see what happens. If it were just belts i'd do it myself but don't want to pay for a tensioner if I can get Ford to pay
jberzerker is offline
post #23 of 34 Old 06-28-2010, 08:56 PM Thread Starter
a truck
Matt P's Avatar
oh ok yeah if they say they are cool with it then Id say take it in, my biggest fear would just be a ford rep randomly showing up like they do sometimes, but if should be out of there pretty quick if thats all they are doing
Matt P is offline
post #24 of 34 Old 07-16-2010, 10:08 PM
rodo's Avatar
Anybody have the TSB for the idler pulley??
-2016 F250 FX4 Powerstroke
-2015 Ram 1500 Ecodiesel
rodo is offline
post #25 of 34 Old 11-03-2010, 10:03 AM
^X2 I have a bad sqeak and would like to get a new tensioner installed if that is in fact the problem
08SuperDiesel is offline
post #26 of 34 Old 01-24-2011, 10:01 PM
It's Time
Well, 81,000 miles, my belt has been making noise for a while now, just last weekend started tearing itself apart (I heard it and found pieces of it under the truck) and I think I am going to take it on this weekend. I don't have all my tools as I am working out of town, so does anybody that has done it have any suggestions on what special tools are needed besides sockets. I heard somebody talking about a thin tensioner bar, but I addume this is not needed if the procedure mentioned is followed. . .
post #27 of 34 Old 01-24-2011, 11:52 PM
TSB
09-9-8 6.4L DIESEL - COLD WEATHER BELT CHIRP
Publication Date: May 6, 2009
FORD: 2008-2009 F-Super Duty
This article supersedes TSB 07-23-9 to update model year, Service Procedure and Part List.
ISSUE:
Some 2008-2009 F-Super Duty vehicles equipped with a 6.4L diesel may exhibit a front end accessory drive (FEAD) belt chirp when initially started following a cold soak.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
On 2008 model year vehicles built on or before 11/9/2007 and equipped with single alternator, replace the idler pulley following Workshop Manual Section 303-05. (Figure 1)
Figure 1 - Article 09-9-8
On 2008 model year vehicles built on or before 11/9/2007 and equipped with dual alternator, replace the idler pulley following Workshop Manual Section 303-05. (Figure 1)
On 2008 and 2009 model year vehicles equipped with single alternator, replace the main FEAD drive belt with a new service belt that has an improved noise resistant rubber compound.
PART NUMBER PART NAME
7C3Z-8678-B Idler Pulley
AC3Z-8620-A Belt
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
1991 Ranger - 38" TSL's, 3 link, One tons, 5.38s on King air shocks....under construction.
1997 Ranger - reg cab flare side, 3.0L, M5OD-R1, 4x4, 31x10.50r15 MT's.
2008 F350 - Crewcab short bed, 6.4L diesel, H&S XRT Pro, AFE DOC/DPF delete
1972 Mustang Coupe - 302, c4, 9", 4.11's locked.
WildStyle is offline
post #28 of 34 Old 01-26-2011, 06:59 AM
Send a message via Yahoo to skipnay
I had my belt replaced around 10k-20k miles because it was squeeling. First they put some kind of pi$$ on it. That just made me mad. So I'm good with not doing mine for a while but I was also told if you had two people you could do it without removing the shroud or fan. Not sure if I trust that or not but that is what I was told.
2010 My Wife has 2 Full time JOBS NOW
2008 F250 H&S MiniMaxx, S&B CAI, and cat/pdf delete
2008 Brute Force 800 All hooked up 67hp to the wheels
2007 Got Married
2004 KFX 700 Stock Bore Kit XX cams
1990 Mustang Notch getting ready to hook it up
1988 Mustang GT 449hp to the wheels 6sp Getting a cage installed
skipnay is offline
post #29 of 34 Old 12-30-2011, 07:10 PM
lhsnbsaoa's Avatar
Garage
thanks for the write up , im gonna tackle this this spring i guess. im at 140,xxx miles and never changed my belts. while im doing egr delete etc i might as well toss on some new belts?
1996 F350 Dually Centurion
Previous trucks: 2003 F-250, 1997 F-350 CCLB, 2000 F-350 CCLB, 2008 F-250 CCLB
lhsnbsaoa is offline
post #30 of 34 Old 12-31-2011, 06:23 AM
Ryan Rønning's Avatar
Quoted: 6 Post(s)
THanks for the write up Matt.
Project Frankenstein
1997 Ford F-350, Dually conversion, Cobra 29 LX CB, 12000 watt converter, All LED lights, TW tunes, 4" DP, Napa Intake, coolant filter, 140cc Injectors and lots of running lights.
Originally Posted by XPLOSIV View Post
Thanks. I'll give er a good wackin in the morning.
Ryan Rønning is offline
