Black Smoke on Accel. - Ford Powerstroke Diesel Forum
Old 05-31-2010, 06:15 PM
Well, 15,000 kms and my first issue. It just started to emit black smoke from the tailpipe when I give it some throttle, light or heavy, doesn't matter. Even at idle if I give it some juice it will puff out some black smoke. Happened after a 300km round trip towing our 7000 lb trailer. No check engine light, runs fine as far as I can tell. My guess would be a cracked DPF, but we'll see when I take it in next tuesday.
Old 05-31-2010, 08:48 PM
sounds like a cracked or clogged dpf as you stated.
you shouldnt have any problems with the dealer fixing that for you at all
Old 05-31-2010, 08:59 PM
if it's a cracked dpf shouldn't their be an mpg increase?
Old 05-31-2010, 09:00 PM
Cracked DPFs could actually cause more restriction and permanent regen cycle (more smoke)
Old 05-31-2010, 09:02 PM
That would be nice! I wouldn't want to fix it then
My MPG is exactly the same as before.
It's not much black smoke, but enough that I can see it when I give it some throttle / accelerate in my passenger side mirror.
Old 05-31-2010, 10:12 PM
Mine was cracked. Got better mpg and less regen. I did take it to the dealer to have it replaced before I deleted it.
Old 05-31-2010, 10:19 PM
I guess i depends on how it cracked?
Old 06-01-2010, 05:44 AM
Did it smoke?
