can an f350 dually haul a loaded 3 car trailer? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 05-24-2010, 08:07 PM Thread Starter
i am starting an auto transport business and want to use my 08 f350 6.4 dually to haul a 3 car trailer every day
can the 350 do this or am i goign to need a 450
i see ram 3500s doing alllll the time!
dairyman123 is offline
post #2 of 8 Old 05-24-2010, 08:08 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
You should be able to with no problem. Might want to put a set of helper air springs on the back and make sure your load doesn't put yu over legal weight limits.
dhanna6powerstroke is offline
post #3 of 8 Old 05-24-2010, 08:24 PM Thread Starter
i was planning on getting the air bag suspension and a spartan tuner!
post #4 of 8 Old 05-24-2010, 09:37 PM
StarDriver's Avatar
You can do it but, you'll need all of your DOT requirements, plus, if your over 26,001 gross, you'll need IFTA also.
You will definitely need the airbags.
If I was you, I'd leave the 350 sit and go buy a used semi tractor for $15,000,trust me, you'll be money ahead.
2006 F-350 4X4 FX4 Tuscany Longhorn , Leer Custom bed cap, RECON lights, Upfitter switches, Whelen Lighting, Hi-Idle Mod.
Instructor at B.R.A.K.E.S (
28 years Commercial Driver.
StarDriver is offline
post #5 of 8 Old 05-24-2010, 10:47 PM
Send a message via AIM to cj performance
Yea semi well worth ur money
Boilermakers Local 374
08 Harley F350
spartan 310
S&B intake
4 in straightpipe to 6 inch dual wall mbrp tip
Rize 8" 4 link, Rize rear springs. Rize steering stabilizer
Fox 2.0 rezzi even on the steering stabalizer
supercrew sounds sub box with 2 10"
DDM 6K HID hi low/and fogs
20x12 weld 854 Dakar wheels
36x15.50x20 mickey thompsons
Rhino Lined
cj performance is offline
post #6 of 8 Old 05-25-2010, 09:25 AM
StarDriver's Avatar
Cool
If your interested in a single axle semi tractor, let me know, I can get you hooked up with used ones that came off of a fleet lease. You can buy these for around $15,000 and you'll get close to the same milage as what you'll bet with the 6.4.
post #7 of 8 Old 05-25-2010, 03:23 PM
Pahrump's Avatar
It will do it no problems...but if your buying to hot shot with and use/abuse the truck like this everyday then I would also go with the single axle BIG truck and not a pickup....take my word for it...I did the hotshot thing myself a few years back.
2008 F250 FX4 CC SB Black on Black STOCK and SLOW...Rolled over and TOTALED...
2008 White with Black interior FX4 CCSB
Black C6 Vette
As far as actual HP numbers I have no idea. It don't snap your neck but.....It feels good.
Pahrump is offline
post #8 of 8 Old 05-25-2010, 03:46 PM
StarDriver's Avatar
I'm starting to see alot more 3-4 car haulers with semi tractors pulling them, the market is flooded with trucks right now. The Pete I bought in my signature, I could buy 2 of them for what a new dually costs and it will last 5 times longer.
If you run steady at all, your pickup will be worn out in 2 years.
I hope you have a contract with someone as there aren't alot of cars moving right now and I know of several companies that have locked their doors because of low pay, no cars. I talked with a broker the other day that got stiffed by a client for over $40,000.
