transmission fluid ????
Yesterday, when fixing the trans fluid temp sensor, the parts person at the Ford Dealership gave me Mercon LV fluid instead of Mercon SP. I did not realize it until this morning (after I have put it in and drove it about 100 miles). What do I need to do?? Drain and refill with SP? Will this hurt my tranny?
Ok...after doing a little searching on the internet, it looks as if the LV replaced the SP:
TECH TIPS TO THE FORD DEALERS Approval to Service ALL 5R110 Automatic Transmissions with MERCONŽ LV Beginning immediately ALL (2003 to 2010 MY) 5R110 automatic transmissions can be serviced with MERCONŽ LV automatic transmission fluid in place of MERCONŽ SP. Initially only the 2009/10MY 5R110 automatic transmissions were filled and serviced with MERCONŽ LV. In an effort to reduce complexity, Ford Motor Company is allowing all previous model year 5R110 automatic transmissions to be serviced with MERCONŽ LV automatic transmission fluid. This pertains to top off as well as fluid replacement. Mixing of MERCONŽ LV and MERCONŽ SP in the 5R110 transmission is acceptable. Extensive testing has been performed to insure there are no functional or durability concerns with the use of MERCONŽ LV in the 5R110 automatic transmission. Vehicles affected are F-Series Super Duty trucks (including chassis cab, motorhome, LCF). |
Interesting, i knew they changed the fluid but i bought my truck used and was curious as to which fluid to top it off with since i didnt know what was in there. I now know i they can be mixed, thanks
