help...stuck on side of road - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-22-2010, 12:46 PM Thread Starter
rodo's Avatar
Trans is throwing these two codes; p0710 and p0713. Both are transmission fluid sensor faults. Changing tune right now to stock no dpf and seeing if that helps. Can drive, but it is making a loud noise like a fan, shifting hard and not going into overdrive.
-2016 F250 FX4 Powerstroke
-2015 Ram 1500 Ecodiesel
rodo is offline
post #2 of 5 Old 05-22-2010, 12:57 PM
powerhoghp's Avatar
Stupid question, but how is your fluid level? Also,How many miles? What tune do you usually use?
powerhoghp is offline
post #3 of 5 Old 05-22-2010, 08:05 PM Thread Starter
rodo's Avatar
Called the closest dealership, which was open until 5 today, and told them what was going on. Limped it to a buddies house (was still 2 hours from home), and changed out the trans temp sensor by dropping the trans pan, and it fixed my problem. They had several in stock, because they said it happens quite often.
rodo is offline
post #4 of 5 Old 05-22-2010, 08:20 PM
Well that makes for a crappy day but at least you got her up and running again. Good info to know for the future.
rlpzzz is offline
post #5 of 5 Old 05-23-2010, 04:35 PM Thread Starter
rodo's Avatar
Part number for the transmission fluid temperture sensor is: 3C3Z-7H141-AA
rodo is offline
