First Oil Change
Ok, I seem to be having to make a descision and I need help. I just picked up my 2010 F250 Lariat 2 weeks ago, and the salesman said that the first service should be done at 1000 miles, he explained that his dealership is "old school" since they have been in business here on Long Island for 61 years that they like to get the factory oil out with any shavings and anything that was filtered out of the engine at 1000 miles. Well, I hit 1000 miles yesterday and I called them up and asked what was done at the first service, the receptionist on the phone said that they do an oil change, I asked how much the service would be and she said around $180.00. I thought that was very high, since I took my 2004 F250 to another dealer for oil changes on occasion and I paid around $130.00. I called my previous dealer and they told me not to have the oil changed until 5000 miles, that it was a waste of money. So, my question is, do I have it changed now or wait until 5000 miles? Also, I will probably change it myself, what oil is recommended to use? Any advice would be helpful.
5000 miles, and every 5000 miles after.
5K miles, and every 5 after that if you use conventional oil. If you choose to use synthetics then I would say stick with the recommendations of the oil manufacturer.
If you still have the dpf and emissions stuff on don't go past 5k as the oil dilution get's unacceptable. No matter what kind of oil you use...
The dealer is just being extremely careful. They have a point about metal floating around. But the newer engines now days should have closer tolerances than the engines say 25 years ago. But I'm no engineer. Do what you feel most comfortable with.
I recommend, motorcraft filters. |
The fuel dilution issue is a problem, but not all trucks have that issue. IMHO if you want to find out if your truck has this issue, once you have reached an acceptable interval, say 4500 miles, perform oil analysis at least the first time to determine if your truck is one of those that will have this issue.
The trucks that will have the issue more than others are those that are daily drivers that do not get run for long enough periods for the exhaust to get or stay hot enough to burn the soot out of the DPF with "PAssive Regeneration". These trucks due to the minimal miles driven often are the ones that go into "Active Regeneration" more often and thus have the fuel dilution issues. If you work your truck, or drive it more than just a few miles per day going back and forth to work, you will most likely not have this issue as the truck will burn off the soot naturally or "passively" from the heat of the exhaust. However, it is always a good idea to have oil analysis done at least once to determine whether your truck and driving style are those that will use the Active Regeneration mode to clean the DPF. I also agree though, that this is the case, no matter what oil you use, the oil itself has little to nothing to do with the fuel dilution issue, some oils just protect better than others in diluted conditions. |
I'm quite sure this horse has been beat to death
![]() But, why does the Ford factory manual state 10k miles? Most posters here seem to have pretty strong opinions that 5k is the way to go. Is this just an ultra conservative approach or what? In sme ways, it feels a bit like a pitch. And of course that sales guys all say "yeah, 10k is the interval unless you are towing all the time. This offsets the higher cost of oil changes compared to a gasser". One stealership I caled said 5k, the other said 10k. I'm a PSd newbie, and I do want to make sure I'm doing things right, but I also tend to take a moderate approach over an ultar-conservative. Just looking to understand this a bit better. Mike |
At 5K I switched to syn and my dealer has me coming in every 7500 based on how the oil looks.
The 10K is for what they call normal driving, not heavy or extreme driving so no stop and go traffic, no towing, no dusty roads, etc.. Most trucks aren't driven in that manner so they are subject to the more frequent oil changes. |
every 5K here
Dave |
