Any suggestions? - Ford Powerstroke Diesel Forum
Old 05-20-2010, 07:32 PM
Any suggestions?
I heard changing the fuel filter under the drivers side can be a head ache to change! Any suggestions to make it an easier first filter change?
Old 05-20-2010, 07:53 PM
shhhhh, can you hear it?
i heard that extensions are the key to success and less blood loss
Old 05-20-2010, 08:08 PM
KING of BLING!
Do it on a lift if you can. I guess they made it a b i t c h on purpose.
Old 05-20-2010, 08:15 PM
What you mean by an extension ?
Old 05-21-2010, 03:22 AM
like for a ratchet
Old 05-21-2010, 04:22 AM
The easiest way is to pay someone to do it. If you do it yourself, use a 36mm socket with a couple of extensions on it and wear old clothes that you don't care about (you will most likely take a diesel bath).
Old 05-21-2010, 06:03 AM
Sears makes a short 36mm socket just for this. It's 3/8 drive and works on the oil filter cap as well. I haven't used mine on the fuel filter yet but I don't think you need all the extensions with it. If you use a standard socket you'll need plenty of extensions.
Old 05-21-2010, 06:57 AM
Feedback Score: -1 reviews
The extensions make your life way easier, I usually use about 25" of extension and it works pretty good. I cant remember the exact lenght but its alot.
