3.55 Gears and 35" Toyos - Bad Idea? - Ford Powerstroke Diesel Forum
Old 05-18-2010, 05:32 AM
I just picked up my 2010 F250 (Switched over from a 2008 Durmax) and LOVE it! I'm thinking about changing from stock tires to a 35" Toyo MT. Is this a bad idea with my 3.55 gear? I ran the same tire on my Duramax and lost mpg and when going up hill the truck would downshift.
Any help would be appreciated!
THANKS!
Old 05-18-2010, 06:57 AM
Send a message via AIM to 1tonpower
your going to notice it just like you did in the durra slap.
theres a 10inch difference in circumference between a 32 and a 35 inch tire.
thats going to change your 3.55 to more like 3.25s
Old 05-18-2010, 07:04 AM
What tire and rim combo did you have from the factory? Because the 275/65/20 that come factory are over 34". I didn't notice that big of a difference switching to the 285/65/20 (34.8"). Hope this helps.
Old 05-18-2010, 07:06 AM
I guess it would have helped to post that tidbit! Yes, I did get the 275/65/20. Thanks for the replies.
Old 05-18-2010, 07:09 AM
You'll have to put some pics up after you switch the tires. 35's look so much better than the 275. I have to find a good AT 35 for my next tire that can get some serious miles out of.
Old 05-18-2010, 07:11 AM
I went from the continetal 33s to toyo 35 ATs and went from 14.2 to 12.8 on avg. on the lie-o-meter. No problem on the down shifting though, but I have the 3.73s.
Old 05-18-2010, 07:19 AM
If you have the 275/65/20 the difference will be minimal. Your stock tire is already 34x11x20. I doubt you will notice excessive downshifting. Your mpg may suffer minimally, but not much.
Old 05-18-2010, 07:32 AM
I'm interested in this too. I have the factory 275/65/20's and 3.55's. I'd like to at least go 35's, maybe even 37 toyo's. I was afraid the 37's may just be too much for the 3.55's though. Anybody made these changes and did some towing afterwards for comparison??
Old 05-18-2010, 07:58 AM
disregard my last...moving from a 34 to a 35 with give you an adjust ratio of 3.45...go for it
Old 05-18-2010, 09:43 AM
I lost about 2.5 mpg's when I went to the 35 Toyo MT's. Still plenty of power though.
