Fuel gauge question
How accurate are the fuel gauges? Yesterday I was on empty, dash read out said I had 30 miles till empty but when I filled up I was only able to get 25 gallons in. I have the 35 gallon tank. thanks, Mike
Depends on how full you fill your tank. I use my dasdaq to read my fuel level percentage. And its actually pretty accurate after you get under the full line because if you fill your tank like I do which is topping it off it stays at 99.997 for awhile. As far as your miles to empty it all depends on what your lie-o-meter is saying so I wouldn't gauge my distance on that.
I always just take an average of my miles to the tank....mine being 29 gallons and topping it off to the neck I normally get 490-500 miles per tank...so I just set the trip every time a I fill up and gauge it that way
When my thing hit 0 miles to E.. it started hesitate as I rolled into gas station.. I donor if all 08's display that but that's what I go off of
I don't let it get below 1/4 tank. I don't like walking.
I'm with Grease...walking sucks. I would trust the gauge over the dash display. I'm sure the display, not the Dashdaq, tries to calculate driving habits..heavy in the pedal.
I have been fighting with FORD about this issue since I bought my truck 2+ years ago. 30.5 gallon tank, gauge reads empty and display reads 0 miles to empty and the most I can get in the tank is 24-25 gallons. I have taken the truck in 3 times for this issue and everytime they tell me nothing is wrong, but can't explain why I can't get more fuel in it. The last time their reason was that the tank is so long that that with 3-4 gallons of fuel laying in the bottom of the tank it would be spread out and probably not registering on the gauges. I have given up, but may get a 5 gallon can of fuel and drive the truck til it starts acting like it is out of fuel just to see how much farther I can go past the 0 miles to empty message.
Yea ur gauge is off I can fit 30g in mine when it says 0
Same here. I took mine in once, and they said nothing is wrong with it. Pulled out a tech bulletin where Ford is saying that they put about a 5-gallon buffer in that reading. But, like you, I don't like walking, so I always fill it up after I get below 50 MTE. |
