PowerSteering Fluid Question - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-09-2010, 08:35 AM Thread Starter
FisherFord's Avatar
Does anyone know what the 6.4's rolled off the line with for Powersteering fluid? I know they have ATF in them, but curious which ATF. I just changed the fluid and filter in my tranmission last weekend, and I noticed today that the power steering was a little low, I have some Mercon LV left over I thought about using to top it off until I have time for a full flush, but not sure what's in it, or if I should mix with the LV?
2008 F250 CC FX4,Spartan,FloPro Cat/DPF Delete, Magnaflow Exhaust, S&B Intake,Kenwood DNX8120
FisherFord is offline
post #2 of 6 Old 05-09-2010, 02:08 PM
Iqoair's Avatar
Just give Ford parts dept. a quick call, they should be able to tell you that right away.
2013 F-350 Platinum
35" Toyo Mud Terrains on stock HD rims
2.5" leveling kit
Firestone Airbags
Bilstein 5100 shocks
Iqoair is offline
post #3 of 6 Old 05-09-2010, 07:41 PM
dieselkane's Avatar
If it keeps running low, check the weep hole under your hydroboost for leakage. I had to have my hydroboost replaced a few months ago because it was leaking where it mounts to the master cylinder.
Traded.. 03 6.0 PSD
For.. Black F250 2008 SD LARIAT 6.4 PSD 4x4, Aries Bull Bar, Westin chrome running bars, Dura Liner, B&W Gooseneck hitch, Recon smoked taillights, Icon 4.5" lift, 35" Toyo M/T, etc... Running Spartan Tunes
AFE PG 7, Flo Pro 4" DP Back, thanks to Cobb's Diesel. It has been great so far.
Originally Posted by azkcr View Post
So all that work and you're keeping the trash can of doom on the exhaust?
dieselkane is offline
post #4 of 6 Old 05-09-2010, 08:01 PM Thread Starter
FisherFord's Avatar
Thanks, I will give them a call tomorrow, just thought I would ask so I could do it today
post #5 of 6 Old 05-09-2010, 08:04 PM Thread Starter
FisherFord's Avatar
appreciate it, its just a little low, but I do my best to keep up on all the fluids. I will check what you mentioned, hopefully thats not the case
post #6 of 6 Old 05-10-2010, 03:27 AM
greasltn's Avatar
I think the manual called for regular mercon.
-John
Rudy's Diesel Performance - 919-383-9300 - Diesel Tech
greasltn is offline
