so i installed newton lift and??? - Ford Powerstroke Diesel Forum
Old 05-08-2010, 08:00 PM
well i installed a newton 1'25 inch lift in my f250 crew cab and now i have a noise coming from the front end somewere when i let of the throttle at 60-55. Anyone else have this happen?? thanks
Old 05-08-2010, 08:10 PM
That's odd, since it's just a spacer block. I put a 2.5" Newton lift in mine with 0 problems. Pretty cut and dry procedure.
I also installed the provided track bar spacers.
Old 05-08-2010, 08:20 PM
just had this same conversation with a forum member last week, still have no answers. I have an Icon 7" and have the same thing happen on the freeway when I let off the throttle. I've got 6k miles on the lift with this symptom, but I've had no issues. I would like to know what's going on also, but I'm not that worried about it at this point. Good Luck
Old 05-09-2010, 01:12 PM
Did you drop the carrier with that 7" lift?
Old 05-09-2010, 01:22 PM
I used the supplied shims from Icon for that. I lifted the truck with 150 miles on it so it might have done the same thing from new. Its pretty much always been lifted
