3.55 gears vs 3.73
Any one know the difference in gas mileage between a PS with 3.55 vs one with 3.73? Any other differences beyond the obvious towing capabilities?
towing capabilities are no different at all. 3.55s do .5-1 mpg better at freeway speeds.
You use more fuel to get up to speed, you use less once your cruising, the difference is probably very small.
Not to hijack the thread, but how do the 3.55 do with 35 or 37 inch tires as far as power and fuel mileage?
I would prefer 3.55 but it doesnt really matter. 3.73 are really good to have if you tow a lot. It seems like a good balance gear.
PoPo5.0: Gear ratio directly affects rated towing capacity. Hence why the F450 doesn't come with the lower gear ratio options. A truck with 3.55 would get better MPG on the highway while NOT towing, but the 3.73's might do better with a trailer in tow as the engine is not struggling as much. With these trucks MPG is more about the way you drive it than gear ratios.
On my truck, and I think most 6.4's, the sweet spot for the best MPG is just below 2000 rpm. So a truck with 3.55's would probably get the same mileage as a truck with 3.73's if the RPM's were the same on a given trial. As for going up in tire sizes, I'd think 3.73's would be ideal if you were to go with a 37" tire. Lots of people on here have lots to say about this subject. But remember, math is math, and there's benefits to both ratios. |
