Batteries / Spartan question - Ford Powerstroke Diesel Forum
post #1 of 10 Old 04-19-2010, 06:14 AM Thread Starter
A8050266's Avatar
Send a message via AIM to A8050266 Send a message via MSN to A8050266 Send a message via Yahoo to A8050266
All,
Any info regarding this would be helpful.
My ride is 08 F250 with Spartan tunes 210 and DPF delete pipe installed.
And still under warranty. 30K miles
Woke this am to semi dead batteries. not completely dead but dead enough it would not start. seems like the past several days the truck has been a little more difficult to start I was wondering if something was wrong and now I know...
Re-flashing the factory tunes back on is quick and painless. but putting the pipe back on is well not so painless . I spoke with my Service Rep. she says
if its just an electrical related issue. dont worry about re installing the pipe.
and if it turns into a Motor issue I can retrieve the truck to install the pipe.
so from the dealers perspective I'm good to go.
my real worries are. If I put the stock tunes back on it. So it it safe to do this and leave the DPF/cat del pip in place. or NOT?
I figure Ill flash the stock tunes back into the truck and drive to the dealership 30: min ride.
Any thoughts if this a sound plan?
TIA
-=Sam
813.390.0040 / Sales, engineering, and floor sweeping. (mostly the sweeping)
2015 F350 CC FX4/Lariot SWD Platinum white
A8050266 is offline
post #2 of 10 Old 04-19-2010, 06:50 AM
I think that will make it go into constant regen.
walkeru08 is offline
post #3 of 10 Old 04-19-2010, 08:12 AM
1tonpower's Avatar
Send a message via AIM to 1tonpower
i would start simple..do a draw test and find out what circuit is using power when it shouldnt be....un hook both batters negatives and put a test light in line with the ground and the battery. the light should light up. then pull fuses till it goes out. then look to why its on when it shouldnt be.
08 f350 KMC wheels with 33" MTZs, bed rails with a reese 20k slider, 5% tint all around, 60gal fuel box, kenwood monitor, afe drop in filter, livewire w/innovative tunes, sinister egr delete, twisted stage 3 trans
1tonpower is offline
post #4 of 10 Old 04-19-2010, 08:13 AM
1tonpower's Avatar
ps dont drive the truck with stock tune and no dpf
post #5 of 10 Old 04-19-2010, 01:24 PM Thread Starter
A8050266's Avatar
Spoke to Spartan today, They said it should go into constant regen which should make it smoke like hell (Since its dumping xtra fuel and not doing the xtra burn). otherwise it should be ok. So, Im going to drive to the DLR then re flash.... once they are done I'll flash back.
-=Sam
A8050266 is offline
post #6 of 10 Old 04-20-2010, 07:21 AM Thread Starter
A8050266's Avatar
Ok so here is the conclusion.
Went to the dealer prepared to flash my truck back to stock while there.
I didnt have too. They took it back and found both batteries to be weak. replaced them
and Im done! GOOD JOB G. Ford! Also thanks to SpartanDT for the updated tunes. even though I did have to use them at this point
-=Sam
A8050266 is offline
post #7 of 10 Old 04-20-2010, 06:32 PM
CEEEJ's Avatar
how was the ride with stock tune a delete pipes?
2008
F250 FX4 CCSB
H&S XRT Pro / Stealth Delete
No Limit Cold Side Kit w/ egr gone
Icon 2.5 Level w/ adj track bar
OEM F350 blocks in rear
CEEEJ is offline
post #8 of 10 Old 04-21-2010, 07:19 PM
HoosierHick's Avatar
Yea my stock batteries were junk as well, I had to replace mine at about 40,000 miles. The Ford batteries are weak to begin with anyways.
2008 F250 POWERSTROKE DIESEL
Fully Loaded Lariat 4x4 SuperCab
Spartan Tuned--275
DPF Delete, MBRP Exhaust, AFE Intake
35" Toyo M/T's
Paid for by the hard work of a 17 year old
HoosierHick is offline
post #9 of 10 Old 04-21-2010, 07:26 PM Thread Starter
A8050266's Avatar
Dont know I never used that tune. I have it but have not tried it.
I went straight to the 210 tune. and never looked back except
when I have to shake in fear of going to the dealer. but thats not happened yet. (crossing my fingers still)
-=Sam
A8050266 is offline
post #10 of 10 Old 04-21-2010, 11:30 PM
What happened with your dashdaq pod? It was a nice design.
powerstroke43 is offline
