questions about doing front brakes - Ford Powerstroke Diesel Forum
Old 04-07-2010, 10:37 AM
is it straight forward? I have done brakes on passenger cars but never on a 4x4/hubs up front, is there anything different on these trucks? are the ceramic pads a good upgrade?
thanks
Old 04-07-2010, 01:43 PM
thanks
It's as easy or easier IMHO. I haven't done them yet on my 08 but it appears similar to my 95 F-150 which was cake. Hardest thing is probably moving around the big heavy wheel.
I'm looking at the service manual and it looks like it's just that easy.
Generally ceramic brakes make for a good upgrade.
Old 04-07-2010, 02:19 PM
thanks for the info
do you know if the rotors come off easily after removing the caliper?
Old 04-07-2010, 03:43 PM
Send a message via MSN to Dusten
if you are removing the rotor then you are going to be required to remove the hub
Old 04-07-2010, 04:31 PM
I just checked my FSM and the "hub" is really just a hub extender. The front axle hub containing the 4wd stuff stays put. Remove the hub extender and the rotor comes off after it.
Dave
Old 04-07-2010, 04:53 PM
thanks guys I will be doing the brakes tomorrow morning
Old 04-07-2010, 05:04 PM
thats good to know, not that i will own my truck long enough to do brakes, but good to know
Old 04-07-2010, 05:08 PM
what you upgrading to?
Old 04-07-2010, 05:53 PM
thanks
Same as a passenger car, just bigger parts.
