Installing factory brake controller on f-350, need help - Ford Powerstroke Diesel Forum
Old 04-04-2010, 11:42 AM
Hi guys,
Ok here's the scoop. My 09 F-350 HD did not come with the factory IBC, for whatever lame reason. Anyways, after some research here, I've installed the factory dash brake controller unit that plugs into the trailer brake harness, with the slide on it. I've also installed the brake master cylinder that is designed to work with the factory IBC. I took it ford to have the computer programmed / feature turned on, the tech brought me back and explained that there is no feature to his knowledge that needs to be turned on or programmed, just plug in the trailer and go. Anyways today, plugged in my trailer, lights, brake lights , signals, all work ok, but the brakes do not work, and I get nothing on the cluster showing that it's plugged in. The gain / manual slide buttons do nothing. I've also checked the 30amp high current fuse in the engine compartment, and the 10 amp fuse in the passenger side fuse panel (All good). What am I missing here?
Hopefully someone else has been through this. Thanks in advance, and appreciate any help or suggestions.
Old 04-06-2010, 04:41 PM
Bump ,
Thanks
Old 04-06-2010, 04:51 PM
When I was looking into this, I was told by the Ford Dealership (has done this several times), that you do have to program the truck.
Old 04-07-2010, 05:32 PM
Fixed! The solution was to take it to a competent dealer. I was in and out within an hour, they updated the computer for the trailer brakes, and also updated the PCM software as a bonus. Total bill was $81.00 with tax.
The total for getting everything done :
Brake Master Cylinder $300.00
Dash trailer brake controller $ 50 (Ebay!)
Programming $80.00
Labour - Did it myself. 1.5 hrs maybe total.
The dealer wanted $1300 to do it all.
Old 04-07-2010, 06:19 PM
sounds good!Great info!Good luck
Old 04-08-2010, 07:47 PM
Powerstroke Techie
Yeah, I was gonna say...
MODULE PROGRAMMING
PROGRAMMABLE OPTIONS (or something)
PERSONALITY
TRAILER BRAKE CONTROLLER
click EQUIPPED.
