More SMOKE!?? - Ford Powerstroke Diesel Forum
Old 03-23-2010, 05:26 PM
More SMOKE!??
How do i EASILY turn my injector pump up? I want to get alil more smoke from the truck.
Old 03-23-2010, 05:28 PM
shaking things up
you want more smoke plug up the intake
Old 03-23-2010, 06:43 PM
Send a message via AIM to PSDfreak
Your truck has a Diesel Particulate Filter...
Old 03-23-2010, 07:27 PM
Is your truck even tuned? If not forget about it.
Old 03-23-2010, 07:37 PM
haha. i know that. i aint that ignorant. ya i have an SCT livewire extreme and a DPF/CAT delete pipe. it blows some smoke but i wanted to turn up the injector a bit for some more. and i know turing one of the screws (not 100% sure which one) it will cut down on turbo lag and give you some more "power" at lower rpms. (1100 and below).
Old 03-23-2010, 07:44 PM
your truck isnt an idi you cant just turn a screw like an old truck, you have a direct injection engine.. if you want to waste fuel and roll coal you need different tunes.
Old 03-23-2010, 08:23 PM
ahhh. i knew it wouldnt be as easy as my old truck! haha i know quite abit about the older fords. but now with all this new b/s they are puttin into trucks these days it has takin some gettin used to. Any suggestions about getting/wat codes to get?
Old 03-23-2010, 08:48 PM
Uh newer trucks wont smoke like that unless you got big injectors and such....
Old 03-23-2010, 08:59 PM
Shade tree mechanic
I vote for the bag over the intake.
bag and ducktape works good. seen it done....
