2 odd problems with the 08 f350 - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-22-2010, 06:50 PM Thread Starter
first, the other day I put the key in the ignition and it would not turn at all, like it was seized (I could take the key in and out). My buddy said to try to tap the key about 50 times to loosen pins inside, and after 15 mins it worked and the key was able to turn. Now it feels like it wants to seize again and not turn, but it has not left me stranded again.. yet.
other problem is there is a whining noise that I noticed every time I drive now, it is like a howling that sounds like brakes that need changing, but the noise is almost always there, and gets louder under braking. I checked all the brakes and they are good pads. sometimes the noise is louder under turning too, very strange,
both issues do not seem to be covered under the 100k warranty so I do not think I will take it in yet..
thanks in advance
2009 f250
H0USE is offline
post #2 of 6 Old 03-23-2010, 04:40 AM
greasltn's Avatar
Do both keys do the same thing in the ignition? If so try using some graphite in the cylinder. Does your brake pedal feel strange? Check your powersteering fluid.
-John
Rudy's Diesel Performance - 919-383-9300 - Diesel Tech
greasltn is offline
post #3 of 6 Old 03-23-2010, 11:33 AM Thread Starter
great idea, I will have to find the other key and check it out,
pedal feels good ,I will check the fluid
thanks
2009 f250
H0USE is offline
post #4 of 6 Old 03-24-2010, 05:49 AM
Slick02's Avatar
I suggest checking the wheel bearings for your whining noise.
08 F350 Lariat SWB 4x4
Spartan tunes (120 & 210)
Pro Flo DPF/cat delete 4" syst/with muffler
AFE stage II intake
2 1/2" leveling kit/Icon adj track rod
Rancho 9000 shocks
Autopage alarm/remote start
Clarion MAX675VDII/800 watt amp and 10" sub
SS black chrome side vent screens
MotoMetal 951's with Toyo 325/60R20 A/T's
Bushwacker flares/painted to match trim
Harley grille
More to come(cause I can't ever leave well enough alone)
Slick02 is offline
post #5 of 6 Old 03-24-2010, 11:16 PM
KEY BIZ.....
Take the strain off the steering lock and the key will turn... There is just a bit of pressure there, relieve that and bingo, key works just fine...
Noise, get service before damage, maybe wheel bearings or carrier bearing on rear driveshaft is out...
Regards, from Oz...
Lone Ranger is offline
post #6 of 6 Old 03-25-2010, 07:01 AM
Blk04Snake's Avatar
Originally Posted by Lone Ranger View Post
KEY BIZ.....
Regards, from Oz...
Bingo.. There is steering pressure against the lock. Just try turning the steering wheel one way or the other slightly and the key will move nice and easy.
2010 F250 Lariat CC/SB, Icon 2.5, 35s on 20s, Spartan, AFE 4" SS Downpipe back. RIP 1/13/10
2010 F350 Lariat CC/SB BDS leveling kit, BMF, Toyo, Recon, N-Fab, Spartan, AFE, Flo-Pro, MBRP
Blk04Snake is offline
