Upfitter Switches? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-09-2010, 01:28 PM Thread Starter
InMotionJosh's Avatar
Upfitter Switches?
If I wanted to hook up an LED light bar to the upfitter switches how would I do this. Is there a wiring diagram? Do I need relays and such?
2013 CCSB Lariat Ultimate
H&S/AmpResearch/FloPro/MBRP/Recon/AFE More To Come
InMotionJosh is offline
post #2 of 7 Old 03-09-2010, 04:26 PM
kcschultz's Avatar
First, you could hook up an led lightbar to an upfitter switch. As to whether you will need a relay, that depens on the amperage draw of the lightbar. If it exceeds 30amps, then definately.
kcschultz is offline
post #3 of 7 Old 03-09-2010, 05:53 PM Thread Starter
Amperage definatly wont exceed 30 amps. So basically the wire to which ever switch i choose is hot when the switch is on and I would just need to hook that to the light and ground the other wire from the light?
post #4 of 7 Old 03-09-2010, 06:49 PM
kcschultz's Avatar
That would be correct. You have 2 20amp and 2 30amp switches, choose whichever one best suits your application and that will be the positive, then ground the negative to a location that is convenient. Should work fine.
post #5 of 7 Old 03-09-2010, 07:03 PM
jimd1050's Avatar
Quoted: 2 Post(s)
Cool
Correction: According to Ford's Q-117-R1 Document, AUX 1 is 30 Amp, AUX 2 is 30 AMP, AUX 3 is 10 AMP and AUX 4 is 15 AMP and all of these switches are feeding relays. Your 4 "Blunt Cut Wires" as they call them, are relay outputs at the above current values. Just Google "Ford Q-117-R1" and you get a PDF of the instructions including a schematic.
Regards... Jim D
'08 F250XLT Super Duty 4X4
Intake, Tuning and Exhaust... Back to Banks
Suspension/Drivetrain by WC Motorsports
jimd1050 is offline
post #6 of 7 Old 05-02-2013, 08:15 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
so glad you put that up, now I don't have to ask for a diagram lol
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #7 of 7 Old 05-03-2013, 05:08 AM
theplumbingmedic's Avatar
Good info thanks Jim
2010 F350 lariat cc sb srw
H&S Black Maxx,S&B CAI,,Readylift leveling kit,,GY 325/60/20,Smoked Recon: tail lights,cab lights,3rd brake light and tow mirror lights,AVS smoked window vents,20% window tints,Curt front mount hitch,Rear hitch mounted lights,Sinister coolant filter,PMF dual steering stabilizer,PMF traction bars 51 Gal. Titan tank,Bilstein 5100`s,Rudy`s up pipes,ARP studs,RCD egr delete w/ elbow,AFE cold side pipe,AFE 4"dp, AFE 5"
exhaust
theplumbingmedic is offline
