About to do a Flo Pro 4" turbo back, I also purchased titanium pipe wrap for the turbo down pipe, apparently the down pipe is a 2 piece unit, so question is what's the easiest way to wrap the downpipe seeing as it's a 2 piece affair
Wrap the piece that connects to the turbo, I suppose you could wrap the lower half as well but you would have to avoid wrapping the area where you clamp the two together.
I wrapped the top half of mine when I did it, I used stainless hose clamps.
The old one is "fun" to get out, I recommend wrestling it out as much as you can and then cutting it in half to get it completely removed.
I imagine taping the top piece as far down as you can go and finish wrapping the bottom after installation. I can't remember if there was room to or not.
What do you have in there now? If you can post back and let me know how you like it. Is it with the muffler? I'm thinking of going with the same but 5".
I ordered 4" turbo back
All the way 4" with muffler
And I will put original tail pipe on
May need work on that tip?
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
