Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > General 6.4L Discussion
Old 10-30-2009, 08:08 PM
diesel daddy diesel daddy is offline
smoke and fumes
After doing a burn out the other day I noticed some smoke coming out from under the cab of the truck I can also smell diesel fumes in the truck. I noticed it a little before I did the delete and the tunes however it has gotten much worse and I can hear what sounds like exhaust leak from under the cab. I checked the exhaust system w installed and its all tight with no leaks. It seems to be coming out near the firewall behind the engine. I dont know whats back there as I havent looked Im guessing a flex pipe of some sort. If anyone knows what Ive done please help thanks
Old 11-02-2009, 08:56 AM
wontonrunner wontonrunner is offline
You have an exhaust leak between your turbo and the downpipe. It is a very common occurance and mostly only noticeable during regen. I drove my truck like that last year and was told by one dealership its normal. I have since switched dealerships. There is a TSB out for this which describes fumes in the cab and smoke from the wheel wells and the vents infront of the window. The leak is at the turbo/downpipe right below the fresh air intake. Its was a big problem for many of the Job 1's.
Its a warranty issue and takes a day to get it fixed...Cab has to come off. I just had mine done last week.
