Warranty info needed - Ford Powerstroke Diesel Forum
post #1 of 9 Old 06-22-2009, 01:09 AM Thread Starter
07lariat's Avatar
Can anyone tell me what the powertrain warranty is for a 2007 F250 diesel? I've read a few threads on other sites saying that it is 5 yr / 160000km but I can't find anything from Ford backing that up. The only thing I can find from Ford says only the engine is warrantied, nothing about the tranny. My tranny is shifting hard from 2nd to 3rd and I don't know if I should take it to the dealer or a tranny shop. I've got 83000 kms on the odo.
07lariat is offline
post #2 of 9 Old 06-22-2009, 01:23 AM
ADMIN AND TECH
SCUFFY828's Avatar
ford factory warranty is 5 years 100,000 miles , that only includes engine and some attaching parts , trans is only warrantied for up to 36,000 miles
ITS STOCK
SCUFFY828 is offline
post #3 of 9 Old 06-22-2009, 02:39 AM
2007's came w/ a complimentary 5 yr / 60k Powertrain warranty
Mark
06 F250CC SB FX4 Lariat;ARP studs;OEM gaskets; Banks exhaust;DynaTrac Ball joints;Coolant filter; High-Idle;RACCCV6000;JimmiJammers;Ravelco;SynchroMax trans case;Fumoto valves;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's; BPD EGR cooler;One-piece HPOP fitting;BilletWaterPump;SCT w/ Matts SRL;ELC Ultra
bismic is offline
post #4 of 9 Old 06-22-2009, 03:10 AM Thread Starter
07lariat's Avatar
Where can I find this "complimentary warranty" info. I had the truck into the dealer because the front axle dust seals had fallen out and they told me there was only warranty on the motor. I have read that some dealerships don't know or play dumb about the complimentary warranty issue.
07lariat is offline
post #5 of 9 Old 06-22-2009, 04:30 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 9 Post(s)
Wrong there were a few 06's and a few 07's that had this warranty, and in most cases you paid for it
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #6 of 9 Old 06-22-2009, 07:18 PM
I disagree (based on what I was told by a Ford employee) - Ford issued complimentary powertrain warranty's on 2006 models that were made after July 14, 2006. According to my info from Ford- all 2007's had this also. I guess it could be a regional thing - but that is not what I was told.
OP -
Get an OASIS report - it will have it listed (if you have it). At first, I was not told about mine (I did not pay for it either). I discovered it initially by reading it on my OASIS report. I also had to point it out to my dealership when I had some work done (I took my OASIS report w/ me).
Also - The front axle seals are not covered on the Powertrain warranty (IIRC).
this is what was sent to me:
*F-Series (up to F-550) diesel engine warranty coverage is 5 years/100,000 miles. A 2006 Model Year Ford vehicle sold on or after July 14, 2006 will be covered by a complimentary 5year/60,000 Mile Ford ESP PowertrainCARE extended service contract with a $100 deductible. For 2007 Model Year Ford products the warranty is fully transferable with no deductible.
Mark
bismic is offline
post #7 of 9 Old 06-22-2009, 07:40 PM
Here is an announcement on it:
Warranty Week, Ford's New Powertrain Warranties, 25 July 2006
here is another:
Ford Adds Two Years to Powertrain Warranties
.... another (although this is from a specific dealership):
THE 5 YEAR/60,000 MILE POWERTRAIN WARRANTY - FORD OF OCALA - Free-Press-Release.com
and ....here is another:
Ford tacks on another two years to powertrain warranties
Mark
bismic is offline
post #8 of 9 Old 06-23-2009, 03:23 PM Thread Starter
07lariat's Avatar
Thanks for the info and the links. I'll have a go with the dealer and find out what their story is.
07lariat is offline
post #9 of 9 Old 06-23-2009, 06:24 PM
This is what is covered (I was wrong - the axle seals should be covered):
5 yr 60k Complimentary PowertrainCARE Warranty
ENGINE
• All Internal Lubricated Parts
• Cylinder Block
• Cylinder Heads
• Flywheel
• Manifold (Exhaust and Intake)
• Manifold and Bolts
• Oil Pan
• Oil Pump
• Seals and Gaskets
• Thermostat
• Thermostat Housing
• Timing Chain Cover
• Timing Chain (Gears or Belt)
• Turbocharger/Supercharger Unit (Factory Installed)
• Valve Covers
• Water Pump
TRANSMISSION
• All Internal Parts
• Seals and Gaskets
• Torque Converter
• Transfer Case (Including All Internal Parts)
• Transmission Case
REAR-WHEEL DRIVE AXLE
• Axle Shafts
• Bearings (Front and Rear)
• Drive Axle Housing and Front Axle Housing for 4x4 (Including All Internal Parts)
• Driveshaft
• Retainers
• Seals and Gaskets
• Universal and Constant Velocity Joints
FRONT-WHEEL DRIVE AXLE
• Axle Shafts
• Final Drive Housing and Rear Axle Housing for AWD (Including All Internal Parts)
• Hubs, Automatic Front Locking (Four-Wheel Drive)
• Locking Rings (Four-Wheel Drive)
• Seals and Gaskets
Plus, you get other valuable benefits:
Cross Countryฎ Motor Club, Inc.†
membership — for 24-hour roadside
assistance, call 1-800-241-3673 toll-free
• Flat-tire change
• Battery jump starts
• Towing and towing reimbursement
• Out-of-fuel assistance
• Travel expense reimbursement
or destination assistance
†Cross Countryฎ Motor Club, Inc., of Alaska, California, Hawaii,
Oregon, Wisconsin and Wyoming.
Rental Car Reimbursement
• Up to 10 days per repair visit*
• $30 per day ($36 per day for Lincoln)
• Includes repairs covered by the Bumperto-
Bumper New Vehicle Limited Warranty
*Requires the vehicle to be kept overnight for covered repairs
Mark
bismic is offline
