Cat Removal Question - Ford Powerstroke Diesel Forum
post #1 of 17 Old 06-20-2009, 08:44 PM Thread Starter
Stroker920's Avatar
I went to try and remove my cat and was having trouble with the back clamp on my '03. I got the front off fine but on the back, I got the nut off but couldnt get anything to budge. How did it go when anyone else did it? Did you just loosen the bolt and pull on the cat until it came loose?
Stroker920 is offline
post #2 of 17 Old 06-20-2009, 09:27 PM
mine slid right off just like it was a fresh install. Guess I was lucky, but if everything is loose lay on your back and give it a few good kicks, just dont let it fall on you! That dude is pretty heavy for its size.
Ruben
2008 F250 4x4 6.4PSD Auto
Tuned, deleted, studded, piped, bts'd...
Rubenk is offline
post #3 of 17 Old 06-20-2009, 09:33 PM Thread Starter
Stroker920's Avatar
When you took the nut of the back clamp, did the clamp loosen or anything?
post #4 of 17 Old 06-20-2009, 10:24 PM Thread Starter
Stroker920's Avatar
I just tried kickin it out. The darn thing wont budge. I know I have to get this clamp loose first. Any help?
Obama don't own Ford!
“If people concentrated on the really important things in life, there'd be a shortage of fishing poles.”
-Doug Larson
post #5 of 17 Old 06-20-2009, 10:43 PM
Coal Rolling = Posing
Soak it with BBblaster, and have a couple beers... Make sure everything threaded is removed, and carefully whack it with a hammer.
Repeat as required...
chvyrkr is offline
post #6 of 17 Old 06-20-2009, 11:01 PM
Tennessee Powerstrokes
GoFastPadre's Avatar
He means PB Blaster, that stuff works miricals.
Get your self a small prybar or big screwdriver, altho I do not recomend useing anything except the right tool for the job, and pry the clamp apart after letting the PB Blaster work its majic. Then kick it like you mean it.
To reach GoFastPadre
Official Chapter Area
GoFastPadre is offline
post #7 of 17 Old 06-20-2009, 11:04 PM
BB...
PB...
They both work lol
chvyrkr is offline
post #8 of 17 Old 06-20-2009, 11:06 PM
You can probably fit a flat tip under it and GENTLY pry it loose. Put some kinda lube/penatrant on it for a bit though
chvyrkr is offline
post #9 of 17 Old 06-21-2009, 06:44 PM
Mudvain's Avatar
i gently manuevered my sawzall into position and carefully squeezed the almost hair trigger setting that it has until said pipe was cut
Mudvain is offline
post #10 of 17 Old 06-21-2009, 07:24 PM Thread Starter
Stroker920's Avatar
That's what I'm thinkin.
-Doug Larson
